Showing results for tags 'dimensions to excel'.
  1. Hello, I've seen threads of people with similar requests. I have a different issue, I need to extract only the dimensions noted as "F.S." in the attached DWG file for each individual window. the Excel file should look like the attached image. So the method used needs to recognize the window name (A, B) and list the dimensions for the respective window in the Excel file. Any help would be very appreciated!, thank you in advance! Elevations.dwg
