Showing results for tags 'excel to cad'.
  1. Quickly exports a table of Lines and Texts or Attribute blocks to a Table For the table of unknown attribute blocks, please use BURST command to burst all blocks first. General Usage Instructions BlockToExcel - Export table of attribute block or Lines and Texts to excel You can download the supported table styles from here https://www.mediafire.com/file/4u2zun3l12smtjc/Table_English.dwg/file If your table includes Lines and Texts or Unknown attribute blocks: 1. Run the BURST command to explode all attribute blocks 2. Run the B2E command. - Select all exploded objects. - Specify steel layer (if any). - Enter to finish command. Download: https://apps.autodesk.com/ACAD_E/en/Detail/HelpDoc?appId=4761456461459704560&appLang=en&os=Win32_64 Source: www.lisp.vn
  2. Dear Friends and Experts, Again I am here with a new problem got a new project again Now here i have an excel sheet and it was pasted as a link ( i think) as i got this project my client is not having the excel sheet. i have only the CAD file in which the excel sheet is pasted same as excel sheet ("not in table format") Normally when i double click the Excel sheet or the OLE object it directly opens in to an excel file, here its not happening it tells me "Failed to launch Server application" tried by right clicking the object right click-OLE-Convert that dosent change anything:| please help i am attaching the drawing as well S14006-0100D-PH1-CU-FD-EG-701.dwg
  3. Dear All my well wishers...please solve my typical problem..please..my data as below(From Excel) S.No. Length(m) From To Remarks 1. 10 11.5 soil 2. 13 14 soil 3. 10 11.5 concrete strata 4. 10 12 Bitumen Strata How to draw lines from above data(From Excel) by importing, using visual lisp.PLEASE RESPOND POSITIVELYY.PLZZZZ BAR CHAR INPUT DATA.xlsx GRAPH FINAL OUTPUT.dwg
