Showing results for tags 'expire date'.
hi, i need to help about expire date for a lisp function. i hardly write following lisp and i want to add an expire date in it. it will be vlx file and it shuld be not valid at 01/01/2017. And it needs a warning like "this function is expired!" the lisp is; (defun c:MKAtman () (command "CMDECHO" "0")(terpri) (prompt "Setting layers")(princ) (command "layer" "unlock" "*" "thaw" "*" "on" "*" "") (command "layer" "m" "0" "c" "7" "" "l" "Continuous" "" "") (if(not(tblsearch "LAYER" "000_Ahşap")) (command "layer" "m" "000_Ahşap" "c" "white" "" "l" "Continuous" "" "d" "Ahşap İmalatlar" "000_Ahşap" "") (command "layer" "m" "000_Ahşap" "c" "white" "" "l" "Continuous" "" "d" "Ahşap İmalatlar" "000_Ahşap" "y" "")) (if(not(tblsearch "LAYER" "000_Andezit")) (command "layer" "m" "000_Andezit" "c" "250" "" "l" "Continuous" "" "d" "Andezit Döşeme Kaplamaları" "000_Andezit" "") (command "layer" "m" "000_Andezit" "c" "250" "" "l" "Continuous" "" "d" "Andezit Döşeme Kaplamaları" "000_Andezit" "y" "")) (if(not(tblsearch "LAYER" "000_Antet")) (command "layer" "m" "000_Antet" "c" "251" "" "l" "Continuous" "" "d" "ABB Antet" "000_Antet" "") (command "layer" "m" "000_Antet" "c" "251" "" "l" "Continuous" "" "d" " ABB Antet" "000_Antet" "y" "")) (if(not(tblsearch "LAYER" "000_Beton Parke")) (command "layer" "m" "000_Beton Parke" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_Beton Parke" "") (command "layer" "m" "000_Beton Parke" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_Beton Parke" "y" "")) (if(not(tblsearch "LAYER" "000_Bitki")) (command "layer" "m" "000_Bitki" "c" "white" "" "l" "Continuous" "" "d" "N/A" "000_Bitki" "") (command "layer" "m" "000_Bitki" "c" "white" "" "l" "Continuous" "" "d" "N/A" "000_Bitki" "y" "")) (if(not(tblsearch "LAYER" "000_Bitki İz")) (command "layer" "m" "000_Bitki İz" "c" "white" "" "l" "Continuous" "" "d" "N/A" "000_Bitki İz" "") (command "layer" "m" "000_Bitki İz" "c" "white" "" "l" "Continuous" "" "d" "N/A" "000_Bitki İz" "y" "")) (if(not(tblsearch "LAYER" "000_Bordür")) (command "layer" "m" "000_Bordür" "c" "180" "" "l" "Continuous" "" "d" "N/A" "000_Bordür" "") (command "layer" "m" "000_Bordür" "c" "180" "" "l" "Continuous" "" "d" "N/A" "000_Bordür" "y" "")) (if(not(tblsearch "LAYER" "000_Çim Tarama")) (command "layer" "m" "000_Çim Tarama" "c" "64" "" "l" "Continuous" "" "d" "169,185,167" "000_Çim Tarama" "") (command "layer" "m" "000_Çim Tarama" "c" "64" "" "l" "Continuous" "" "d" "169,185,167" "000_Çim Tarama" "y" "")) (if(not(tblsearch "LAYER" "000_Duvar")) (command "layer" "m" "000_Duvar" "c" "19" "" "l" "Continuous" "" "d" "N/A" "000_Duvar" "") (command "layer" "m" "000_Duvar" "c" "19" "" "l" "Continuous" "" "d" "N/A" "000_Duvar" "y" "")) (if(not(tblsearch "LAYER" "000_EPDM")) (command "layer" "m" "000_EPDM" "c" "white" "" "l" "Continuous" "" "d" "142,95,87" "000_EPDM" "") (command "layer" "m" "000_EPDM" "c" "white" "" "l" "Continuous" "" "d" "142,95,87" "000_EPDM" "y" "")) (if(not(tblsearch "LAYER" "000_Eski Eğri")) (command "layer" "m" "000_Eski Eğri" "c" "253" "" "l" "Dashed2" "" "d" "N/A" "000_Eski Eğri" "") (command "layer" "m" "000_Eski Eğri" "c" "253" "" "l" "Dashed2" "" "d" "N/A" "000_Eski Eğri" "y" "")) (if(not(tblsearch "LAYER" "000_Havuz")) (command "layer" "m" "000_Havuz" "c" "132" "" "l" "Continuous" "" "d" "N/A" "000_Havuz" "") (command "layer" "m" "000_Havuz" "c" "132" "" "l" "Continuous" "" "d" "N/A" "000_Havuz" "y" "")) (if(not(tblsearch "LAYER" "000_Kauçuk")) (command "layer" "m" "000_Kauçuk" "c" "white" "" "l" "Continuous" "" "d" "142,95,87" "000_Kauçuk" "") (command "layer" "m" "000_Kauçuk" "c" "white" "" "l" "Continuous" "" "d" "142,95,87" "000_Kauçuk" "y" "")) (if(not(tblsearch "LAYER" "000_Kent Mobilyası")) (command "layer" "m" "000_Kent Mobilyası" "c" "white" "" "l" "Continuous" "" "d" "N/A" "000_Kent Mobilyası" "") (command "layer" "m" "000_Kent Mobilyası" "c" "white" "" "l" "Continuous" "" "d" "N/A" "000_Kent Mobilyası" "y" "")) (if(not(tblsearch "LAYER" "000_Koşu Yolu")) (command "layer" "m" "000_Koşu Yolu" "c" "34" "" "l" "Continuous" "" "d" "N/A" "000_Koşu Yolu" "") (command "layer" "m" "000_Koşu Yolu" "c" "34" "" "l" "Continuous" "" "d" "N/A" "000_Koşu Yolu" "y" "")) (if(not(tblsearch "LAYER" "000_KüpTaş")) (command "layer" "m" "000_KüpTaş" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_KüpTaş" "") (command "layer" "m" "000_KüpTaş" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_KüpTaş" "y" "")) (if(not(tblsearch "LAYER" "000_Mevsimlik Tarama")) (command "layer" "m" "000_Mevsimlik Tarama" "c" "210" "" "l" "Continuous" "" "d" "N/A" "000_Mevsimlik Tarama" "") (command "layer" "m" "000_Mevsimlik Tarama" "c" "210" "" "l" "Continuous" "" "d" "N/A" "000_Mevsimlik Tarama" "y" "")) (if(not(tblsearch "LAYER" "000_Ölçü")) (command "layer" "m" "000_Ölçü" "c" "217" "" "l" "Continuous" "" "d" "N/A" "000_Ölçü" "") (command "layer" "m" "000_Ölçü" "c" "217" "" "l" "Continuous" "" "d" "N/A" "000_Ölçü" "y" "")) (if(not(tblsearch "LAYER" "000_Sert Tarama")) (command "layer" "m" "000_Sert Tarama" "c" "white" "" "l" "Continuous" "" "d" "N/A" "000_Sert Tarama" "") (command "layer" "m" "000_Sert Tarama" "c" "white" "" "l" "Continuous" "" "d" "N/A" "000_Sert Tarama" "y" "")) (if(not(tblsearch "LAYER" "000_Sınır")) (command "layer" "m" "000_Sınır" "c" "20" "" "l" "Continuous" "" "d" "N/A" "000_Sınır" "") (command "layer" "m" "000_Sınır" "c" "20" "" "l" "Continuous" "" "d" "N/A" "000_Sınır" "y" "")) (if(not(tblsearch "LAYER" "000_Slopeticks")) (command "layer" "m" "000_Slopeticks" "c" "252" "" "l" "Continuous" "" "d" "Şev Çizgisi" "000_Slopeticks" "") (command "layer" "m" "000_Slopeticks" "c" "252" "" "l" "Continuous" "" "d" "Şev Çizgisi" "000_Slopeticks" "y" "")) (if(not(tblsearch "LAYER" "000_Tasarım")) (command "layer" "m" "000_Tasarım" "c" "50" "" "l" "Continuous" "" "d" "N/A" "000_Tasarım" "") (command "layer" "m" "000_Tasarım" "c" "50" "" "l" "Continuous" "" "d" "N/A" "000_Tasarım" "y" "")) (if(not(tblsearch "LAYER" "000_Terrazo Granit AG")) (command "layer" "m" "000_Terrazo Granit AG" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_Terrazo Granit AG" "") (command "layer" "m" "000_Terrazo Granit AG" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_Terrazo Granit AG" "y" "")) (if(not(tblsearch "LAYER" "000_Terrazo Bazalt AG")) (command "layer" "m" "000_Terrazo Bazalt AG" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_Terrazo Bazalt AG" "") (command "layer" "m" "000_Terrazo Bazalt AG" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_Terrazo Bazalt AG" "y" "")) (if(not(tblsearch "LAYER" "000_Terrazo Washbeton Yİ")) (command "layer" "m" "000_Terrazo Washbeton Yİ" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_Terrazo Washbeton Yİ" "") (command "layer" "m" "000_Terrazo Washbeton Yİ" "c" "250" "" "l" "Continuous" "" "d" "N/A" "000_Terrazo Washbeton Yİ" "y" "")) (if(not(tblsearch "LAYER" "000_Yazı")) (command "layer" "m" "000_Yazı" "c" "220" "" "l" "Continuous" "" "d" "N/A" "000_Yazı" "") (command "layer" "m" "000_Yazı" "c" "220" "" "l" "Continuous" "" "d" "N/A" "000_Yazı" "y" "")) (if(not(tblsearch "LAYER" "000_Yeni Eğri")) (command "layer" "m" "000_Yeni Eğri" "c" "20" "" "l" "Continuous" "" "d" "N/A" "000_Yeni Eğri" "") (command "layer" "m" "000_Yeni Eğri" "c" "20" "" "l" "Continuous" "" "d" "N/A" "000_Yeni Eğri" "y" "")) (command "layer" "s" "0" "") (command "CMDECHO" "1") (prompt "Tüm Layerlar Başarıyla Oluşturulmuştur.") (princ) );end defun
