Showing results for tags 'fillet command problem'.
  1. Fillet and chamfer quit working properly. When I try to join 2 lines that are perpendicular nothing happens. The texts on the command line are what they always were with no error messages and ends up with the usual "Command:" after I am done. If I put a distance into the chamfer command it will draw the appropriate chamfer but it will not extend or trim the lines that I am trying to chamfer. It does the same if I enter a diameter into the fillet command. I draws the fillet but the original lines are unchanged. What have I done wrong?
  2. I am trying to draw a detailed representation of an extension spring. Right now I have two slanted parallel lines and I want to connect them using fillet, but I do not want the arc to make these lines longer, I want the arc to be above the line they intersect with, something like this \__\ How do I make the arc be above the line? The purpose is to not change the length of the object from end to end.
  3. Sometimes In AutoCAD 2011, when i fillet two lines very close to each others with radius 0, the first line move closer to the second line instead of extending them in the same direction! Can anyone help?
