Dear AutoCAD users:
We would like to develop a plugin for AutoCAD to create geometries (line/arc/circle/ellipse/polyline etc.) through touchscreen. So instead of using commands, it will be just like freehand drawing, the program will automatically generate shapes to match your touchscreen input.
We want to do a little survey here to see if it makes sense to you? Will you buy it?
One concern is, because touchscreen input is not as precise as through keyboard & mouse, the dimensions might be a little off (e.g. you want to draw a line with a length of 10.5, the program thinks it is a 10), and you will need to make some adjustments afterwards to get the exact size you really want. Would this be problem for you?
Thanks!
Disclaimer: We are a startup working on our own project and have no relations to Autodesk.
