Showing results for tags 'layer states manager'.
  1. Hello I am new to this forum but desperately need some help. I am using Layer States Manager in CAD2010 and have run into this problem. Perhaps I have a setting wrong but I need some help. I inserted an XREF into my drawing which is using LMAN. I put the XREF on a layer that is visible for the current layer state I am in. Saved the drawing then another coworker opened it and the xref was no longer visible. Even though the layer settings show as not frozen or locked the XREF won't show. If I move it onto a layer that is showing in the layer state manager it still doesn't show. I'm not sure if this is just a glitch or if I have some some setting set incorrectly. Any help is appreciated. Also are others have problems with LMAN not working after drawings are opened by someone else in the office? Are the LMAN settings not universal? Thanks
