Showing results for tags 'lisp modification'.
  1. Dear Experts, i need changes in Notepad output file by Lisp program modification. with help of my lisp produced as attached file (File Name is Actual lisp format X coordinates) and i need the format of notepad file as attached file (File Name is Required Format X coordinates). please find these files and kindly modify present lisp program.i have attached sample files of X coordinates. modification required Y coordinates too. My present Code is: ;; gc:distinct (gilles chanteau) ;; Suprime tous les doublons d'une liste ;; ;; Argument ;; l : une liste (defun gc:distinct (l) (if l (cons (car l) (gc:distinct (vl-remove (car l) l))) ) ) (defun l-coor2l-pt (lst flag / ) (if lst (cons (list (car lst) (cadr lst) (if flag (+ (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) (caddr lst)) (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) ) ) (l-coor2l-pt (if flag (cdddr lst) (cddr lst)) flag) ) ) ) (defun c:ptdef2notepad ( / js dxf_cod mod_sel n lremov str_sep oldim ename l_pt l_pr pr l_x l_y tmp1 f_openx tmp2 f_openy) (princ "\nSelect model object for filtering: ") (while (null (setq js (ssget "_+.:E:S" (list '(0 . "*LINE,POINT,ARC,CIRCLE,ELLIPSE,INSERT") (cons 67 (if (eq (getvar "CVPORT") 1) 1 0)) (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model")) ) ) ) ) (princ "\nIsn't an available object!") ) (vl-load-com) (setq dxf_cod (entget (ssname js 0))) (foreach m (foreach n dxf_cod (if (not (member (car n) '(0 67 410 8 6 62 48 420 70))) (setq lremov (cons (car n) lremov)))) (setq dxf_cod (vl-remove (assoc m dxf_cod) dxf_cod)) ) (initget "Single All Manual") (if (eq (setq mod_sel (getkword "\nSelect mode, [single/All/Manual]<Manual>: ")) "Single") (setq n -1) (if (eq mod_sel "All") (setq js (ssget "_X" dxf_cod) n -1) (setq js (ssget dxf_cod) n -1) ) ) (setq str_sep " " ;-> **** YOU CAN CHANGE THIS STRING BY WHAT YOU WONT ! **** <- oldim (getvar "dimzin") ) (setvar "dimzin" 0) (repeat (sslength js) (setq ename (vlax-ename->vla-object (ssname js (setq n (1+ n))))) (setq l_pr (list 'StartPoint 'EndPoint 'Center 'InsertionPoint 'Coordinates 'FitPoints)) (foreach pr l_pr (if (vlax-property-available-p ename pr) (setq l_pt (if (or (eq pr 'Coordinates) (eq pr 'FitPoints)) (append (if (eq (vla-get-ObjectName ename) "AcDbPolyline") (l-coor2l-pt (vlax-get ename pr) nil) (if (and (eq pr 'FitPoints) (zerop (vlax-get ename 'FitTolerance))) (l-coor2l-pt (vlax-get ename 'ControlPoints) T) (l-coor2l-pt (vlax-get ename pr) T) ) ) l_pt ) (append (l-coor2l-pt (vlax-get ename pr) T) l_pt) ) ) ) ) ) (setq l_x (gc:distinct (mapcar '(lambda (x) (rtos (/ x 1.0) 2 2)) (vl-sort (mapcar 'car l_pt) '<)))) ;-> **** YOU CAN CHANGE UNIT AND PREC (rtos x unit prec) ! **** <- (setq l_y (gc:distinct (mapcar '(lambda (x) (rtos (/ x 1.0) 2 2)) (vl-sort (mapcar 'cadr l_pt) '<)))) ;-> **** YOU CAN CHANGE UNIT AND PREC (rtos x unit prec) ! **** <- (setq tmp1 (vl-filename-mktemp "tmp_x.csv") f_openx (open tmp1 "w") ) (write-line (apply 'strcat (mapcar '(lambda (x) (strcat x str_sep)) l_x)) f_openx) (close f_openx) (startapp "notepad" tmp1) (setq tmp2 (vl-filename-mktemp "tmp_y.csv") f_openy (open tmp2 "w") ) (write-line (apply 'strcat (mapcar '(lambda (x) (strcat x str_sep)) l_y)) f_openy) (close f_openy) (startapp "notepad" tmp2) (setvar "dimzin" oldim) (prin1) ) Thanking you, best regards. Actual lisp format X coordinates.txt Required Format X coordiantes.txt Sample Drawing.dwg
  2. Dear Masters, I have one Lisp, with help of my existing lisp generating notepad file. i need CSV file format instead of notepad as a shown image format. Kindly make a modification in my existing Lisp. ;; gc:distinct (gilles chanteau) ;; Suprime tous les doublons d'une liste ;; ;; Argument ;; l : une liste (defun gc:distinct (l) (if l (cons (car l) (gc:distinct (vl-remove (car l) l))) ) ) (defun l-coor2l-pt (lst flag / ) (if lst (cons (list (car lst) (cadr lst) (if flag (+ (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) (caddr lst)) (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) ) ) (l-coor2l-pt (if flag (cdddr lst) (cddr lst)) flag) ) ) ) (defun c:ptdef2notepad ( / js dxf_cod mod_sel n lremov str_sep oldim ename l_pt l_pr pr l_x l_y tmp1 f_openx tmp2 f_openy) (princ "\nSelect model object for filtering: ") (while (null (setq js (ssget "_+.:E:S" (list '(0 . "*LINE,POINT,ARC,CIRCLE,ELLIPSE,INSERT") (cons 67 (if (eq (getvar "CVPORT") 1) 1 0)) (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model")) ) ) ) ) (princ "\nIsn't an available object!") ) (vl-load-com) (setq dxf_cod (entget (ssname js 0))) (foreach m (foreach n dxf_cod (if (not (member (car n) '(0 67 410 8 6 62 48 420 70))) (setq lremov (cons (car n) lremov)))) (setq dxf_cod (vl-remove (assoc m dxf_cod) dxf_cod)) ) (initget "Single All Manual") (if (eq (setq mod_sel (getkword "\nSelect mode, [single/All/Manual]<Manual>: ")) "Single") (setq n -1) (if (eq mod_sel "All") (setq js (ssget "_X" dxf_cod) n -1) (setq js (ssget dxf_cod) n -1) ) ) (setq str_sep " " ;-> **** YOU CAN CHANGE THIS STRING BY WHAT YOU WONT ! **** <- oldim (getvar "dimzin") ) (setvar "dimzin" 0) (repeat (sslength js) (setq ename (vlax-ename->vla-object (ssname js (setq n (1+ n))))) (setq l_pr (list 'StartPoint 'EndPoint 'Center 'InsertionPoint 'Coordinates 'FitPoints)) (foreach pr l_pr (if (vlax-property-available-p ename pr) (setq l_pt (if (or (eq pr 'Coordinates) (eq pr 'FitPoints)) (append (if (eq (vla-get-ObjectName ename) "AcDbPolyline") (l-coor2l-pt (vlax-get ename pr) nil) (if (and (eq pr 'FitPoints) (zerop (vlax-get ename 'FitTolerance))) (l-coor2l-pt (vlax-get ename 'ControlPoints) T) (l-coor2l-pt (vlax-get ename pr) T) ) ) l_pt ) (append (l-coor2l-pt (vlax-get ename pr) T) l_pt) ) ) ) ) ) (setq l_x (gc:distinct (mapcar '(lambda (x) (rtos (/ x 1.0) 2 2)) (vl-sort (mapcar 'car l_pt) '<)))) ;-> **** YOU CAN CHANGE UNIT AND PREC (rtos x unit prec) ! **** <- (setq l_y (gc:distinct (mapcar '(lambda (x) (rtos (/ x 1.0) 2 2)) (vl-sort (mapcar 'cadr l_pt) '<)))) ;-> **** YOU CAN CHANGE UNIT AND PREC (rtos x unit prec) ! **** <- (setq tmp1 (vl-filename-mktemp "tmp_x.csv") f_openx (open tmp1 "w") ) (write-line (apply 'strcat (mapcar '(lambda (x) (strcat x str_sep)) l_x)) f_openx) (close f_openx) (startapp "notepad" tmp1) (setq tmp2 (vl-filename-mktemp "tmp_y.csv") f_openy (open tmp2 "w") ) (write-line (apply 'strcat (mapcar '(lambda (x) (strcat x str_sep)) l_y)) f_openy) (close f_openy) (startapp "notepad" tmp2) (setvar "dimzin" oldim) (prin1) ) Please find sample drawing and sample CSV Format. Thanking you, Best regards. Points export to CSV.dwg
