Showing results for tags 'lisp trans function'.
  1. Hi. My problem is following: I have an INSERT entity with nameDXF "X". I have an nested INSERT (inside "X") with nameDXF "F". Finally, I have a sphere that makes up the INSERT Block reference "F", the property "Position" is (0 0 0). In the drawing the position of the sphere is outside the origin of the WCS. I need to transform the coordinates of the "Position" property of the sphere to the WCS. I thought that this would have a result: (setq T (trans ptoPosition F X)) (trans T X 0) But I get nil in both cases. Any comments on how I should use the TRANS function? Greetings.
