Showing results for tags 'multi-page spread'.
  1. Hello All, I have searched through the forums and the web in general and have not found a solution quite matching my quandary. The attempt or desire is to be able to print a two page 'spread from a single tab layout ... I have currently created two Page Setups, one for the left hand page and one for the right hand page and therefore have to print each layout tab twice - this works but is not very efficient. Generally I do set up one drawing per layout tab but this situation is a little different. I am creating a drawing file with 'Data Sheets' - 30 data sheets, each in its own layout tab with a two 8.5 x 11 page spread per layout tab. The file is for the development of a functional program which as you can imagine will be evolving over a period of time. To address this, page one of the spread describes a given portion of the program and page two presents a schematic portion of that floor plan/relationship via a viewport. I am using AutoCAD 2013 in a Windows 7 machine.
