Showing results for tags 'multiple dimension styles'.
  1. I want to have two dimension styles in one dimension line. The first style would be a point to point dimension with the text centered and above the dimension line. The second style would be a running dimension to each point with the text over the second extension line and above the dimension line. Right now I am using two seperate dimension lines, one on top of the other. I'm trying to find a way to combine them into one dimension line so that I won't have to dimension the same thing twice. At first I thought that using alternate units would work, however I was not able to find a way to seperate the two dimensions. Also, I didn't see how to make the alternate units a running dimension. Does anyone know if I am missing something, or is this just not possible? Any ideas would be greatly appreciated!
