Newbie here. I have an extrusion in a plate producing a nipple. I then did a rectangular pattern thus creating 2000 of these nipples. I want to add a chamfer to the end now. But when I select the "parent" nipple and perform the chamfer it does not replicate on to the other 1999 nipples. Is there a specific comand that will do it to all? In AutoCAD I would've made a block and then done the array and modified the block as needed. Any help is greatly appreciated. Thanks much.
