Showing results for tags 'plotter problem'.
  1. I have an old HP 750C+ plotter I have been able to successfully load a driver on my Windows 7 64 bit computer and have plotted form it. I recently had some changes made to my computer and now cannot seem to install the plotter again. I can create PDF's and plot them with the plotter so I know windows is recognizing the plotter but auto cad will not. When i use the add-a- plotter wizard in auto cad ultimately it will ask me for a saved pcp or pc2 file or select plot to a port which is set up. My question is where can I find these files (PCP, or PC2) or is there another way to set up the plotter so I can plot through Auto Cad. I also know that I have to disable the windows driver signature upon system start up which I have done.
  2. I recently upgraded to Windows 10. At first the problem was that Autocad could not see/find the plotter on the network, after several days of trying to find the problem, updating the plotter driver, etc. it somehow fixed itself... now my problem is that when I send a drawing to the plotter it only plots about half of it (i.e. a 24x36 drawing comes out about a 18x24 plot) full size, not fitted to sheet) meaning it just cuts the sheet in half and I never get the second half. I have reset everything in page setup, reworked sheet sizes, added custom sheets with 24x36 sizes (and other sizes) no no avail... Any suggestions?
