Showing results for tags 'rename blocks'.
Hi, Does anyone have a lisp that will rename blocks? I'm hoping to find something with a list in the lisp with the old and new names (if name doesn't exist just keep checking through the list). I haven't been able to find anything online which does what I was hoping and my skills when it comes to coding are pretty minimal. Thanks, Joe
Hello all, I have a block, (Data Block), which is a listing of data followed by a leader that is pointing to multiple Mechanical Parts in the drawing. Each Part will have it's own (Data Block) but different technical data. I need to create a Lisp routine that would in-able me to insert this block several times and renaming each to match the Part. Do I have to insert the block, explode, make new block, rename it and then reinsert the old block to a new Part and start the process over again several times? What I would like to do is to insert this block for the first Part and rename it as "..."#1, the second Part as "..."#2, etc.
