Showing results for tags 'revision cloud insert'.
  1. Hi All, I found this lisp that would be really helpful at work, trouble is I can only get it to work partially. In short it creates a revision cloud and then inserts a revision tag (a triangle which is saved as a different drawing), the final stage is inserting the revision number(which is entered by user, say 3 for example) in the revision tag. I get to the part where it inserts the revision tag, and then I get the error message: Place the cloud's tag: Unknown command "3". Press F1 for help Here is part of the code: (setq m:REVNUM (getstring "\nEnter the revision set: ")) few lines of code later (setq m:PLACETAG (getpoint "\nPlace the cloud's tag: ")) (command "._insert" "cloudtag" m:PLACETAG (getvar "DIMSCALE") "" "0" m:REVNUM) I believe its something to do with syntax, I want to enter the value stored in m:REVNUM but somehow Im missing something. If it helps Im using Autocad 2010 To view complete code: http://delapp.com/cad/lisp/revcloud.lsp
