Showing results for tags 'round up'.
Hi, I'm looking to add a round up routine in a dimension area routine. i saw a few roud up codes but i don't know were to insert them or if it going to work. here's the area dimension code that we use. We need to have the answer round up to the next .5: 12,02 = 12,5 12,4 = 12,5 12,51=13 12,65=13 etc.. thank you for your help. ;;; Dimension Area ;;; Displays the area calculated from the selection of two Dimensions in an ;;; MText Field Expression using the formatting specified at the top of the code. (defun c:aaa ( / *error* _SelectIf _ObjectID Round acdoc acspc d1 d2 fieldformatting msg predicate pt ) (setq fieldformatting "%lu2%ct4%qf1 PC ") ;; Field Formatting (defun *error* ( msg ) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (defun Round (num dp / fac rm) (setq fac (float (expt 10 dp)) rm (rem (setq num (* fac num)) 1)) (/ (cond ( (zerop rm) (fix num)) ( (< 0.5 rm) (1+ (fix num))) ( (+ (/ 5 fac) (fix num)))) fac)) (defun _SelectIf ( msg pred ) ( (lambda ( f / e ) (while (progn (setvar 'ERRNO 0) (setq e (car (entsel msg))) (cond ( (= 7 (getvar 'ERRNO)) (princ "\nMissed, try again.") ) ( (eq 'ENAME (type e)) (if (and f (null (f e))) (princ "\nInvalid Object.") ) ) ) ) ) e ) (eval pred) ) ) (setq acdoc (vla-get-activedocument (vlax-get-acad-object)) acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'paperspace 'modelspace)) ) (setq _ObjectID (eval (list 'lambda '( obj ) (if (and (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE")) (vlax-method-applicable-p (vla-get-utility acdoc) 'getobjectidstring) ) (list 'vla-getobjectidstring (vla-get-utility acdoc) 'obj ':vlax-false) '(itoa (vla-get-objectid obj)) ) ) ) ) (setq predicate (function (lambda ( x ) (and (eq (cdr (assoc 0 (setq x (entget x)))) "DIMENSION") (member (boole 4 (+ 128 64 32) (cdr (assoc 70 x))) '(0 1)) ) ) ) ) (while (and (setq d1 (_SelectIf "\nSelect 1st Dimension <Exit>: " predicate)) (setq d2 (_SelectIf "\nSelect 2nd Dimension <Exit>: " predicate)) (setq pt (getpoint "\nPoint for Result <Exit>: ")) ) (vla-addmtext acspc (round (vlax-3D-point (trans pt 1 0))) 0.0 (strcat "%<\\AcExpr " "%<\\AcObjProp Object(%<\\_ObjId " (_ObjectID (vlax-ename->vla-object d1)) ">%).Measurement>% * " "%<\\AcObjProp Object(%<\\_ObjId " (_ObjectID (vlax-ename->vla-object d2)) ">%).Measurement>% " "\\f \"" fieldformatting "\">%" ) ) ) (princ) ) (vl-load-com) (princ)
