Showing results for tags 'selection edit'.
  1. Greetings! I'm experiencing problems with slecting objects. Usually, when I double clicked multi line text, I could edit it, now I get a text: "select an MTEXT object:", which basically means I have to select it again. Another example of this is quick selection tool. Usually I selected the objects, then went to quick select pop up screen and under "Apply to:" I selected "Current selection". Now, there's only "Entire drawing" option and if i want current selection, I have to re-select it again. It is very complicated and hard to explain, but I hope someone can figure out what's the problem. This occured recently, but I have no idea why. I checked all the selection options and stuff, but can't seem to figure it out. I attached some screenshots that may help for better understanding. Thanks for any help in advance!
