Showing results for tags 'shortcut menu'.
  1. Int the CUI I have created my own shortcut menu. I wish to assign this to the Ctrl+Click Button 2 mouse button. When I do, it also changes the Shift+Click Button 2 to my new shortcut menu which is not what I want. I want to leave ****_Click Button 2 to the Snap default. Any idea what I am doing wrong?
  2. I would like to add a custom command to the Text Editing Shortcut Menu but cannot find it in the CUI? I am trying to add a command right between "Update Field" and "Convert Field to Text". Can anybody help me find where to insert this command so it will show up in said shortcut menu?
  3. Hi all, Don't know how or why this has happened, but my AutoCAD has suddenly stopped showing the correct shortcut menu's when I right click. This happens both in 'default mode' and 'edit mode'. All I get is the default menu instead of my customised edit menu. I've not edited my CUI nor my right click customisation, but when I've checked them, both are as they should be. I just can't work it out. Also, the delete key won't allow be to delete selected objects anymore. I'm not sure what was the last thing I did before this error occured, but I think at some point I wanted to press the
