Showing results for tags 'title blokc excel vba'.
Insert a title Block from excel into a opened dwt with excel vba
alex140590 posted a topic in .NET, ObjectARX & VBA
Hello there! Can someone help me out? I have make a small Excel VBA project, that opens a dwt file "FLW40_0"(see macro below) with a button. In this dwt I have managed a A3 layout with frame and a title block (see attached file). Now after opnening the dwt I what to insert the title Block that I define in excel file (see sheet "Schriftfeld"). The block schould be on layout down left. Sub FLW40_0() Dim ACAD As Object Dim NewFile As Object Dim MyAcadPath As String Dim bReadOnly As Boolean On Error Resume Next Set ACAD = GetObject(, "ACAD.Application") If (Err 0) Then Err.Clear Set ACAD = CreateObject("autocad.Application") If (Err 0) Then MsgBox "Could Not Load AutoCAD!", vbExclamation End End If End If 'If you want to see AutoCAD on screen ACAD.Visible = False MyAcadPath = "U:\AutoCAD Vorlagen\FLW40_0.dwt" bReadOnly = True Set NewFile = ACAD.Documents.Open(MyAcadPath, bReadOnly) If (NewFile Is Nothing) Then ErrorMessage: If NewFile = "False" Then End MsgBox "Could not find the required spreadsheet that should be located at" & vbCr & MyAcadPath & vbCr & "Please rename or relocate the specified file as needed." End End If 'Close AutoCAD Process 'ACAD.Quit Set ACAD = Nothing Set NewFile = Nothing End Sub Best regards Alex FLW40.rar
