Showing results for tags 'unlocked layers'.
Hello Everyone, I have a lisp that I would like to use but I do not want it to affect locked layers. Could someone point me in the right direction on how to modify this lisp? I'm starting to get familiar with lisp programming but this code looks different than what I have been using. This lisp simply takes all text and puts it on a new layer called "Layer"-Text. I have one layer of text that I do not want to change. I'm hoping to just keep the layer locked while the lisp runs. As always, any help is greatly appreciated. Also does anyone know any good references on lisp for AutoCAD? ToText.lsp (defun c:ToText (/ la name lk ss new);; Move all *Text and *Leaders to a text layer, matching primary layer (eg. ALAN -> ALAN-TEXT);; Includes objects on locked layers;; Layer created if doesn't exist (also takes on color of primary layer);; Alan J. Thompson, 08.19.10(vl-load-com)(vlax-for l (setq la (vla-get-layers(cond (*AcadDoc*)((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))))))(or (wcmatch (strcase (setq name (vla-get-name l))) "*-TEXT,*$*")(if (setq ss (ssget "_X" (list '(0 . "*LEADER,*TEXT") (cons 8 name))))(progn(and (setq lk (eq :vlax-true (vla-get-lock l))) (vla-put-lock l :vlax-false))(or (tblsearch "LAYER" (setq new (strcat name "-TEXT")))(vla-put-color (vla-add la new) (vla-get-color l)))(vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*))(vl-catch-all-apply (function vla-put-layer) (list x new)))(vla-delete ss)(and lk (vla-put-lock l :vlax-true))))))(princ))
