Showing results for tags 'vba error key not found'.
  1. Robert Random
    VBA Key Not Found Error
    Hi. I pasted the following code from a help file, into a new .dvb file and ran it. I used to work fine. Currently it gives me an error (shown below). It used to work fine previously. I reinstalled ACAD and the VBA enabler. Still same. Not sure what to do. Thanks in advance for any helpful advice. ~Robert Sub RemoveMyLayer() On Error Resume Next '' Get the layer "MyLayer" from the Layers collection Dim ABCLayer As AcadLayer Set ABCLayer = ThisDrawing.Layers.Item("MyLayer") '' Check for an error, if no error occurs the layer exists If Err = 0 Then '' Delete the layer ABCLayer.Delete '' Clear the current error Err.Clear '' Get the layer again if it is found the layer could not be removed Set ABCLayer = ThisDrawing.Layers.Item("MyLayer") '' Check for error, if an error is encountered the layer was removed If Err <> 0 Then ThisDrawing.Utility.prompt "'MyLayer' was removed" Else ThisDrawing.Utility.prompt "'MyLayer' could not be removed" End If Else ThisDrawing.Utility.prompt "'MyLayer' does not exist" End If End Sub
