Showing results for tags 'vertical margin'.
  1. Good evening, everyone. When manually creating table styles you can create custom cell styles and set, for each of them, a horizontal and a vertical margin. I'm trying to change an existing table style via LISP. I need to check each cell style, extract the values of its horizontal and vertical margins, multiply those values by a factor and then set these new products as the horizontal and vertical margins of that cell style. My problem is that I don't seem to find reference to cell styles anywhere. I can't find them using entget and I can't find them listed in vlax-dump-object. Is there a way to get the names of all the cell styles defined in a table style? And then is there a way to change the properties of such cell styles (namely the horizontal and vertical cell margins)? The most promising thing I've found so far is the GetCellStyles method (which is supposed to list by name the defined cell styles), but I can't seem to be able to use it correctly. No matter which arguments I supply to it I always get nil. Does anyone know how to use the GetCellStyles method? I thank you all in advance. PS.: there are a HorzCellMargin and a VertCellMargin methods (40 and 41 groups in the tablestyle entity list), but the values there apply only to the standard cell styles ("Data", "Header" and "Title").
