Hi All,
I am having a frustrating issue where VLX files are not loading. AutoCAD will run any LSP files I load, but when I try to load VLX files (that run perfectly on 160 other CAD machine), it just returns nil.
This also occurs when I drag and drop a working VLX into AutCAD. The machines affected are at a remote office, all have the same group policy, and all exhibit the same symptoms. The VLX files are deployed from a central server and are run from the local C drive. All Support Paths are correct (the profile used is common across all machines) and I have confirmed that the files are being copied correctly.
I have investigated the antivirus software and cannot see any references to AutoCAD VLX files.
Are there any settings in AutoCAD that do not allow VLX files to be loaded?
Any help appreciated as I need to get these machines online soon.
Thanks in advance,
Colin Holloway
Sedgman Limited
