Showing results for tags 'width text lisp'.
  1. Oops! - Header should read " Help Modifying Text Width Lisp " I don't know where this code originated (It's pretty old...) but can someone *PLEASE* help me modify it to also work with MTEXT and DIMENSIONS? -Edit 7.29.2010 **After some research, screw MTEXT!! - not worth the hassle! ** I just need it to work with the various dimensions. Associative, Multileader, etc. (DEFUN C:TW (/ P OPTION NSTYLE NWIDTH L N E) (PROMPT "\nChanges text width: ") (setvar "cmdecho" 0) (graphscr) (command "undo" "m") (Prompt "\nSelect text to be changed: ") (setq olderr *error* *error* cterr) (setq p (ssget)) (SETQ OPTION "Width") (cond ((eq option "Width") (setq nwidth (getreal "\nEnter new width for text: ")))) (if p (progn (setq l 0 n (sslength p)) (while (< l n) (if (= "TEXT" (cdr (assoc 0 (setq e (entget (ssname p l)))))) (progn (cond ((eq option "Width") (setq e (subst (cons 41 nwidth) (assoc 41 e) e)))) (entmod e))) (setq l (1+ l))))) (princ)) While I would like to know HOW to modify this code, if there is another routine better suited to change the text width of any "text-related" entities I am open to such as well... Thanks!!
