LitePL Posted January 21, 2008 Share Posted January 21, 2008 I cannot find where to change the default decimal place dimensions are rounded to. I can easily change single dimensions in a project to allow further decimal places. The default is to 2 decimal places (.12). I need it to go to 3 decimal places (.123) by default to all dimensions shown. If someone could show me where exactly to set this option that would be great. I only have 1.5 years experience in Inventor from school classes. I am taking the Project Lead The Way courses. Right now I am finished with the first class, Intro to Engineering, and am on the second, Principles of Engineering. Right now I work on small projects but i plan to develop my knowledge of Engineering and Architecture even further. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 21, 2008 Share Posted January 21, 2008 Are you referring to sketch dimensions in ipt file or drawing dimensions in idw file? ipt > Tools>Document Settings>Units tab and set the Display Precision. in idw is a bit more complex Format>Style Editor... practice around in here a bit - lots of settings or easier, Right click on a dimension and change Precision, then right click on the dimension again and select Copy Properties Quote Link to comment Share on other sites More sharing options...
LitePL Posted January 21, 2008 Author Share Posted January 21, 2008 Many thanks to you. This has been bugging me for a while and finally i can set it to default. Oh and the Styles Editor is in Format not Tools. Quote Link to comment Share on other sites More sharing options...
Mr T Posted January 21, 2008 Share Posted January 21, 2008 Depends on your set std. For me I use GB, then goto Styles Editor, and Check the dims and the 3rd ngle projection. I can save edits as well. Nick Quote Link to comment Share on other sites More sharing options...
alijahed Posted July 13, 2012 Share Posted July 13, 2012 Are you referring to sketch dimensions in ipt file or drawing dimensions in idw file? ipt > Tools>Document Settings>Units tab and set the Display Precision. in idw is a bit more complex Format>Style Editor... practice around in here a bit - lots of settings or easier, Right click on a dimension and change Precision, then right click on the dimension again and select Copy Properties Thanks, at least I found the answer. But it is not a smart way of changing dimensions. Autodesk must look for a smart way like what you can find in AutoCAD. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 13, 2012 Share Posted July 13, 2012 But it is not a smart way of changing dimensions. Autodesk must look for a smart way like what you can find in AutoCAD. You haven't yet learned Inventor. Set it once in your template and forget it - just like AutoCAD. Quote Link to comment Share on other sites More sharing options...
alijahed Posted July 13, 2012 Share Posted July 13, 2012 Well, can you please let me know how to do this not on the template but on an old drawing file? I have an old drawing file, all the dims are like 2.02 and I want to have 2.0. Where can I change the setting? Quote Link to comment Share on other sites More sharing options...
Bishop Posted July 13, 2012 Share Posted July 13, 2012 Well, can you please let me know how to do this not on the template but on an old drawing file?I have an old drawing file, all the dims are like 2.02 and I want to have 2.0. Where can I change the setting? MANAGE --> STYLES EDITOR --> DIMENSION Find whichever dimension style you're using and want to change, then adjust the format and precision to match what you want. Quote Link to comment Share on other sites More sharing options...
alijahed Posted July 20, 2012 Share Posted July 20, 2012 MANAGE --> STYLES EDITOR --> DIMENSION Find whichever dimension style you're using and want to change, then adjust the format and precision to match what you want. Thanks mate. Quote Link to comment Share on other sites More sharing options...
