How do i make a spiral stair stringer in 3d? can you please me? what commands do i use?
well... i saw one a tutorial talk's about how to make a 3d spiral stair .. it was good ...
First.
made a Circle with a radias u want for the stair ,,,
Sec.
use Divide or div .. command to divide the circle equaly and the divide number depends on the stairs numbers u need ...
3rd.
After that use ray command from the center of the circle ...
4th.
use trim to cut the unneeded lines from ray.. then take a slice from the circle ..
5th.
Close the slice by pedit or region or bo commands ... and extrude it ... and this will be the main shape ..
6th.
copy the shape and past it ... and use align command to stick the stairs together... keep doing this till u have a spiral stair :)
i will try to put some pics to help to understand it ...
thnx ...
PHIN: Search this website as this topic has come up before in one shape or form. You'll find plenty of good advice and even some examples.
Start with this thread...http://www.cadtutor.net/forum/showthread.php?t=18329
i need to know how to make the stringer in 3d..
The link I gave has a pretty good example of how to do it.
the stair im buidling has two steel HSS stringer on the side....no post....n open riser....303.87 degree..but im using autocad 2005...what command should i use to build it?
EXTRUDE (along a path appears in the command line) or SWEEP
Nick
PS This was discussed way way back in 2002.
Search on here for the Helix.lsp. This will draw the spiral then you can use ARRAY or MEASURE to arrange the blocks of the stair treads around the spiral and EXTRUDE>Path to do the stringers. If you could post a pic of what you want or a sketch, I will try to do a Tutorial with pics when I have time.
  • 1 year later...
thank you....stairs came out better than expected! :)
  • 2 years later...
