ujin415 Posted April 30, 2009 Posted April 30, 2009 How to open autoCad document by http URL using command line? AutoCad 2007. Quote
NBC Posted April 30, 2009 Posted April 30, 2009 not quite sure exactly what you are trying to achieve here, but I have assumed that you are trying to open Internet Explorer with a specific web address. If that is the case then, it is a 2 step process. It can probably be converted to a lsp file should you need it to be. Step 1: Type START at the command line Step 2: iexplore "type your http URL here" Quote
ujin415 Posted May 4, 2009 Author Posted May 4, 2009 not quite sure exactly what you are trying to achieve here, but I have assumed that you are trying to open Internet Explorer with a specific web address. If that is the case then, it is a 2 step process. It can probably be converted to a lsp file should you need it to be. Step 1: Type START at the command line Step 2: iexplore "type your http URL here" Example: acad.exe "urlWebDavHost/autocad file" Is not working Quote
