Hello,
I apologize if this has already been asked, but is there a way to use fields that allows me to make the same text in multiple spots that updates all spots if you edit the text at any one of those spots?
Thanks!
I would also like to have a field that updates according to the viewport scale of a drawing if anyone knows how to do that. It would be greatly appreciated!
1. If you make a Custom Drawing Properties (File > Drawing Properties... > Custom) you can use them in Fields
2. Field > Objects > Object (pick Viewport) > Custom scale
type field then select object... then select your viewport... then select custom scale & Use scale name & ok it. That will now update when you change your viewport scale accordingly.
pipped at the gate again!! :D
Thanks guys! The suggestions worked perfectly.
