Hey Everyone,
Hope you all are having a good weekend. I just started using vl, vla, vlax commands recently and i was wondering if anyone has input on this portion of my code that gets a selection set of all text on a certain layer and changes the height of it.
 (defun thight ( / dracula textset textlnth eachname)
 (setq textlnth (sslength (setq textset (ssget "X" (list(cons 0 "*TEXT") (cons 8 "C-ANNO-ROAD"))))))
 (setq dracula 0)
   (repeat textlnth
     (setq eachname (ssname textset dracula))
      (vlax-put-property (vlax-ename->vla-object eachname) "height" 2)
     (setq dracula (1+ dracula))
I guess im trying to find the way to make a selection set with vla. Thanks in advance
I would approach it like this:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] thight  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"X"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"*TEXT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]8[/color][/b] [b][color=#ff00ff]"C-ANNO-ROAD"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] Obj  [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vla-put-height[/color][/b] Obj [b][color=#009999]2.0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
I'd use a .bat file.
your a .bat file. lol
Thanks lee. is there another way to get that selection? Know what i mean?
There is, but you won't like it...
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] thight  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss fCode fNme[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]vla-get-SelectionSets[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vlax-for[/color][/b] sSet ss
   [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-name[/color][/b] sSet[b][color=RED])[/color][/b] [b][color=#ff00ff]"NewSs"[/color][/b][b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]vla-delete[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-item[/color][/b] ss [b][color=#ff00ff]"NewSs"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vla-Add[/color][/b] ss [b][color=#ff00ff]"NewSs"[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] fCode [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray-fill[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-safearray[/color][/b]
                 [color=Blue][b]vlax-vbinteger[/b][/color] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] [b][color=#009900]8[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       fNme [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray-fill[/color][/b]
                [color=Blue][b]vlax-vbvariant[/b][/color] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"*TEXT"[/color][/b] [b][color=#ff00ff]"C-ANNO-ROAD"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ObjSet [b][color=RED]([/color][/b][b][color=BLUE]vla-select[/color][/b] NewSs [color=Blue][b]acSelectionSetAll[/b][/color] [b][color=BLUE]nil[/color][/b] [b][color=BLUE]nil[/color][/b] fCode fNme[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vlax-for[/color][/b] Obj ObjSet
lol well nvm ill stick with what i have, Thanks again!
I thought there was a different way than that. If i remember / figure it out ill post it. VL is fun though. Kinda hard to figure out but fun.
Hi
I translate
 (setq dracula 0)
   (repeat textlnth
in vl
(defun c:thight(/ sel txt)
 (vl-load-com)
 (and (ssget "X" (list (cons 0 "TEXT,MTEXT") (cons 8 "C-ANNO-ROAD"))) ; Don't use *text because Rtext
     (vlax-for txt (setq sel (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
   (vla-put-height txt 2)
     (princ (strcat "\nChange " (itoa (vla-get-count sel)) " text."))
     (vla-delete sel)
If you want.
When you use ssget, there are already in activeselectionset and you don't need to create a new selection.
Use the selections in vlisp is really hard, especially with the filters when it is so simple with ssget.
I just wanted to show him how to use the selection sets in VL - another option to ssget.
Also, I have a question for you -
What if you have two selection sets using ssget, how do you operate on these using activeselectionset?
In this choice, I am compelled to do as you indicated at Commandobill, but honestly, with a filter wise enough, I never needed to work with two selections sets.
I can see what you are saying, I was just thinking of the possibilities :)
Hi
why wouldnt i want to scale rtext? Even if by chance i made a mistake and put rtext on that layer i would want it scaled... right?
For example, vla object of rtext doesn't work with acad 2006
