salman Posted May 5, 2009 Posted May 5, 2009 Using autolisp I want to write code using whic One we draw a line, the next line must be drawn at an angle greater to or equal to 90 degree i.e. the angle between first and second line must be 90 or greater ( as required ). Similar is the case for the next line by considering the 2nd line as the base line and so on. Any guidance will be deeply appreciated. Thanks. Quote
CmdrDuh Posted May 5, 2009 Posted May 5, 2009 How do you determine what the angle is? Do you ask your users questions that they answer that determines the angles? Quote
Lee Mac Posted May 5, 2009 Posted May 5, 2009 Just thinking out-loud: [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:AngLne [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] bs1Pt bs2Pt grlst bsAng bs+ bs- bsn lstp sPt cAng[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] bs1Pt [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b] [b][color=#ff00ff]"\nSpecify First Point of Line: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] bs2Pt [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b] bs1Pt [b][color=#ff00ff]"\nSpecify Second Point of Line: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] grlst [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=#009900]3[/color][/b] bs1Pt bs2Pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#009900]2[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] grdat [b][color=RED]([/color][/b][b][color=BLUE]grread[/color][/b] [b][color=BLUE]T[/color][/b] [b][color=#009900]7[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#009900]13[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] grdat[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]redraw[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] bsAng [b][color=RED]([/color][/b]AngCorr [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] grlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] grlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] bs+ [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] bsAng [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] pi [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] bs- [b][color=RED]([/color][/b][b][color=BLUE]-[/color][/b] bsAng [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] pi [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] bsn [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] bsAng [b][color=#009999]-1.0[/color][/b][b][color=RED])[/color][/b] lstp [b][color=RED]([/color][/b][b][color=BLUE]last[/color][/b] grlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#009900]5[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] grdat[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]listp[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] sPt [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] grdat[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cAng [b][color=RED]([/color][/b]AngCorr [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] lstp sPt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]<=[/color][/b] bs- cAng bs+[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]grvecs[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] grlst [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=#009900]3[/color][/b] lstp sPt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] bs+ cAng[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]grvecs[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] grlst [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=#009900]1[/color][/b] lstp [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] lstp [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<=[/color][/b] cAng bsn[b][color=RED])[/color][/b] bs+ bs-[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]distance[/color][/b] lstp sPt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] cAng bs-[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]grvecs[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] grlst [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=#009900]1[/color][/b] lstp [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] lstp [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<=[/color][/b] cAng bsn[b][color=RED])[/color][/b] bs- bs+[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]distance[/color][/b] lstp sPt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#009900]3[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] grdat[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]listp[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] nPt [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] grdat[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] grlst [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] grlst [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=#009900]3[/color][/b] lstp nPt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]command[/color][/b] [b][color=#ff00ff]"_pline"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]command[/color][/b] [b][color=RED]([/color][/b]grAmmend grlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]command[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<!> No Points Selected <!>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]redraw[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] AngCorr [b][color=RED]([/color][/b]ang[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] pi ang[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]-[/color][/b] ang [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] [b][color=#009900]2[/color][/b] pi[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]T[/color][/b] ang[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] grAmmend [b][color=RED]([/color][/b]lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]caddr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]grAmmend [b][color=RED]([/color][/b][b][color=BLUE]cdddr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Hit Enter to stop drawing lines. Quote
