I am doing landscape plans and I need a lisp routine that can help me with the plant quantities for polyline areas. I need it to take the square footage and have a multiplier for specified areas
i.e.
plants spaced on center multiplier
8" 2.60
12" 1.15
15" 0.64
18" 0.50
24" 0.28
30" 0.18
So if I had an area of 100sf that I was planting 12" on center plants
I would multiply 100 x 1.15 to get 11.5 plants
Is there a routine that can be written to select the polyline use it's area then I can enter the on center spacing and it will input the multiplier and give me my plant quantity?
Thanks:oops:
  • Replies 23
  • Lee Mac
    8
  • tcolborn
    8
  • ronjonp
    4
  • TimSpangler
    3
Just a quick one:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:plant [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] cEnt cArea Plnt ans[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] plnt:def [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] plnt:def [b][color=#ff00ff]"8"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cEnt [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect Polyline: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] cEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                     [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"CIRCLE"[/color][/b] [b][color=#ff00ff]"ELLIPSE"[/color][/b] [b][color=#ff00ff]"LWPOLYLINE"[/color][/b] [b][color=#ff00ff]"POLYLINE"[/color][/b] [b][color=#ff00ff]"REGION"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cArea [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Area[/color][/b]
                 [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] cEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]initget[/color][/b] [b][color=#ff00ff]"8 12 15 24 30"[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Plnt [b][color=RED]([/color][/b][b][color=BLUE]getkword[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nArea is: "[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] cArea[b][color=RED])[/color][/b]
                                [b][color=#ff00ff]"\nSelect Center Spacing <"[/color][/b] plnt:def [b][color=#ff00ff]">: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] Plnt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] plnt:def Plnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ans [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] cArea
                [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"8"[/color][/b]  plnt:def[b][color=RED])[/color][/b] [b][color=#009999]2.60[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"12"[/color][/b] plnt:def[b][color=RED])[/color][/b] [b][color=#009999]1.15[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"15"[/color][/b] plnt:def[b][color=RED])[/color][/b] [b][color=#009999]0.64[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"18"[/color][/b] plnt:def[b][color=RED])[/color][/b] [b][color=#009999]0.50[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"24"[/color][/b] plnt:def[b][color=RED])[/color][/b] [b][color=#009999]0.28[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"30"[/color][/b] plnt:def[b][color=RED])[/color][/b] [b][color=#009999]0.18[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nPlant No: "[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] ans[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
(defun c:unameit (/ e area)
 (vl-load-com)
 (if (setq e (ssget '((0 . "LWPOLYLINE"))))
   (progn (setq e (vlax-ename->vla-object (ssname e 0)))
          (setq area (vla-get-area e))
          (if (zerop area)
            (alert "Zero area!")
            (alert (strcat "\n08'' - "
                           (rtos (* area 2.6))
                           "\n12'' - "
                           (rtos (* area 1.15))
                           "\n15'' - "
                           (rtos (* area 0.64))
                           "\n18'' - "
                           (rtos (* area 0.50))
                           "\n24'' - "
                           (rtos (* area 0.28))
                           "\n36'' - "
                           (rtos (* area 0.18))
ronjonp and lee mac both your codes worked great thank you so much. I was hoping it would label the area but the pop up and command line works just as good.
This is the code I used before when I only had to label sf and ac I tried to modify it myself to do what you all created but was unsuccessful I was trying to get it to label sf and then the qty of plants
(defun c:larea (/ hgt pt1 sf ac pt2)
(prompt " \nSelect Polygon: ")
(command "area" "e" pause)
(setq sf (getvar "area"))
(setq ac (/ sf 43560))
(setq sf (rtos sf))
(setq ac (rtos ac 2 2))
(setq sf (strcat sf " S.F."))
(setq ac (strcat ac " Ac."))
(setq pt1 (getpoint "\nEnter Text Insertion Point: "))
(command "text" "M" pt1 0 sf)
(command "text" "" ac)
Just a quick modification, let me know if anything needs changing:
         tPt [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b] [b][color=#ff00ff]"\nSelect Point for Area Text: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b]Make_Text tPt [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] cArea[b][color=RED])[/color][/b] [b][color=#009999]0.0[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b]Make_Text [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] tPt [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] [b][color=#009900]3[/color][/b] pi[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] [b][color=#009999]2.0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=DARKRED]'[/color][/b]TEXTSIZE[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] cArea [b][color=#009999]43560.0[/color][/b][b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [b][color=#009999]0.0[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Make_Text  [b][color=RED]([/color][/b]pt val rot[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]entmake[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"TEXT"[/color][/b][b][color=RED])[/color][/b]
        [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]8[/color][/b] . [b][color=#ff00ff]"TEXT"[/color][/b][b][color=RED])[/color][/b]
        [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]62[/color][/b] . [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]10[/color][/b] pt[b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]40[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"TEXTSIZE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] val[b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]50[/color][/b] rot[b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]7[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"TEXTSTYLE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
        [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]71[/color][/b] . [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]
        [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]72[/color][/b] . [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b]
        [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]73[/color][/b] . [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]11[/color][/b] pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Lee Mac, it puts the same qty no matter what size I pick. I think it's only labeling the sf and acres I don't need acres just sf and plant qty. If you can tweek it can you also have it say sf after the square feet calc.
I was just trying to follow the LISP you posted as best as possible:
   [b][color=RED]([/color][/b]Make_Text tPt [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] cArea[b][color=RED])[/color][/b] [b][color=#ff00ff]" S.F."[/color][/b][b][color=RED])[/color][/b] [b][color=#009999]0.0[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] ans [b][color=#009900]2[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [b][color=#009999]0.0[/color][/b][b][color=RED])[/color][/b]
Lee Mac, you are awesome worked perfectly. Thank you so much. This will help me out greatly.
Tiffany
"Heavy is the head that wears the crown."
Tiffany
Excellent :D
Glad it works for you :)
Lee
Lee
What are you using to syntax color your code?
Hey Tim,
I use a LISP that I modified (originally from David Bethel), that I run the code through to add the colour tags :D
I think I remember seeing that somewhere.
Thanks Lee, I'll check it out.....
Okay so I ran into a snag with this lisp. It works perfect if I'm using decimal units but not so good if I'm using Architectural or Engineering Units. Is there anyway to make it work for the Engineering units in CAD?
Add this: (if (> (getvar 'lunits) 2)
(setq carea (/ carea 144.))
Under this line:
(setq cArea (vla-get-Area
(vlax-ename->vla-object cEnt)))
To get area in feet (assuming your units are set correctly)
I tried adding it in but end up with an error guess I'm not so good at modifying a lisp lol
Select Polyline: ; error: no function definition: VLAX-ENAME->VLA-OBJECT
Tiffany
add this to the top of Lee's code:
(vl-load-com)
