spittle Posted January 29, 2008 Posted January 29, 2008 On the Autodesk website it says they have libraries of ANSI, DIN, ISO and JIS pipe fittings. We use BS EN fittings. I'm wondering if you can get those too? Basically if we can get the sizes of fittings we need then we can get the software. Anyone able to shed some light on this? thanks Quote
Hugh_Compton Posted January 29, 2008 Posted January 29, 2008 You would need to find a third party library - and probably pay for it too. I did a quick google search but didn't find anything so you may need to adapt another standard with the BS values. --------------------------------------- Pipework & Structural Steel http://www.3DCADMax.com Quote
spittle Posted January 29, 2008 Author Posted January 29, 2008 Yeah i had a bit of trouble finding good information, but an engineer at work has pointed out that our pipe manufacturer Saint Gobain's pipes comply with BS, EN & ISO standards so they must be the same. Quote
basiony Posted November 7, 2010 Posted November 7, 2010 but where Can I lead the application in autocad 2011 for fitting the pipe ??? Quote
