Anyone have a simple code so that i can just type 'PJ' and select 2+ polylines and change them into one polyline. I find that i can't always just Fillet them to join.
Thanks in advance :wink:
Zorg
It does, but to repeat that 100 times is kinda fustrating.
didn't know you could do 'multiple'
does this work on arcs ect too?
If you really need it:
(defun c:pj ()
 (setvar "PEDITACCEPT" 1)
 (command "_.pedit" "_M" (ssget) "" "_J" "" "")
 (princ))
EDIT: Yes, will work on Arcs too
Blah! Can't test it out until tomorrow. Need admins password to modify AutoCAD directoy. Needed to know - does this take into account the 'FuzzFactor'? (Fill in the Gaps between polylines)
Z
Just curious, why do you need to alter the AutoCAD directory? Can't you just save it in a folder you can access and load it?
As for Fuzz Factor, it just sets it to 0.00 (just uses default)
Doesn't that mean i'll have to do an AppLoad everytime i bootup AutoCAD?
It doesn't fill in the gaps between polylines, is that to do with the Fuzz Factor? :S
Z
Not necessary. It will load more reliably in the ACADDOC.lsp (but that would mean altering the directory - unless you change the search path), but alternatively, just add the LISP to the start-up suite.
Yes, with the Fuzz factor at zero, the lines will only join if touching.
Is the Fuzz factor a threshold or can you write a lisp so that when i enter PJ and click either line it determines the Fuzz factor and joins the polylines?
Z
I'm learning fast ^^
(defun c:PJ(/ l1 l2 fz)
(if
(and
(setq l1(entsel "\nSelect first line > "))
(setq l2(entsel "\nSelect second line > "))
(setq fz(distance(cadr l1)(cadr l2)))
(vl-cmdf "_.pedit" "_m" (car l1)(car l2) "" "_j" "_j" "_a" fz "")
); end and
(c:jln)
); end if
); end c:PJ
Nice one, just remember to post code in [ code] [/code] tags (without spaces) - makes it easier to read :)
nps! cheers for the heads up
