rkent Posted May 6, 2009 Posted May 6, 2009 I want to take some existing code I found over on another site and change it to add user input. I have added a getstring line but I don't know how to get the program to evaluate that later when needed. So I have a setq ndimtext line, and later I need it to use that setq string in the setq NewDimValue line. Hopefully that makes sense. ; original code from Mike Perry, AUGI NG (defun c:DimAddText (/ DimObject ndimtext NewDimValue) [color=red](setq ndimtext (getstring "Enter text to add to dim: ")) [/color] (princ "\nSelect Dimension to add \(REF.\) to: ") (setq DimObject (ssget '((0 . "DIMENSION")))) (if (not (eq DimObject nil)) (progn (setq NewDimValue "<>\\X\( [color=red]ndimtext[/color] \)") (command "._DimEdit" "_N" NewDimValue DimObject "") ) ) (princ) ) Quote
Lee Mac Posted May 6, 2009 Posted May 6, 2009 Perhaps: ; original code from Mike Perry, AUGI NG (defun c:DimAddText (/ DimObject ndimtext NewDimValue) (vl-load-com) (setq ndimtext (getstring t "\nEnter text to add to dim: ")) (princ "\nSelect Dimension to add \(REF.\) to: ") (if (setq DimObject (ssget '((0 . "DIMENSION")))) (foreach Obj (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex DimObject)))) (vla-put-TextOverride Obj (strcat "<>\\X" ndimtext))) (princ "\n<!> No Dimensions Selected <!>")) (princ)) Quote
Lee Mac Posted May 6, 2009 Posted May 6, 2009 No probs rkent - if you need anything about the code explained, just ask Quote
