Dynko Posted May 7, 2009 Posted May 7, 2009 hi all, this is the problem: i've got a custom component (actually copied from another drawing) and i changed the subcomponents position in block editor (namely positions of some terminals). as i've found out, the place which wires are connected to is designated XxTERMxx in the block editor. Though i moved these XTERMs, back in the drawing when creating a wire it connects to the old position of XTERM. what can i do about this? ty Quote
Dynko Posted May 7, 2009 Author Posted May 7, 2009 ok, found out, that changing positions of connection points of block is not reflected instantenously while changing of regular geometry is, solution is reinsert the block Quote
