need to edit the title block in our template file.
I've opened the title block in the block editor, made the required changes and re-saved.
unfortunately not all of the changes that I have made now appear in the paper space tab. Though it appears correct when I return to the block editor.
The relocation edit I've made to the text and border components appear fine, its the details that have attributes attached that have remained in their original location, or in one case remained after deleting that appear to be a problem.
Anybody help ?
use ATTSYNC to updates any changes to attributes in your blocks.
Be aware, that if you have relocated any attributes in blocks that were already in place (prior to updating the block) the attributes will move to the default location as specified in the block editor.
God I luv this place sometimes.... :shock:
Cheers NBC
