Rhayes Posted February 4, 2008 Posted February 4, 2008 Using ADT 2005 I use a standard Profile and the Mouse works fine I switch to another Profile and the Mouse goes to pan.??? I want to keep the Mouse for Zoom I can not fine out where this is getting changed.??? Quote
Hedgehog Posted February 4, 2008 Posted February 4, 2008 Always look in FAQ before asking :wink: ... http://www.cadtutor.net/faq/questions/11/The+Scroll+Wheel+button+on+my+mouse+will+not+PAN Quote
Rhayes Posted February 4, 2008 Author Posted February 4, 2008 I do check as a rule. The post does not answer my question. I am not asking about PAN. I want my mouse wheel to zoom instead of moving the drawing up & down.?????? Quote
Hedgehog Posted February 4, 2008 Posted February 4, 2008 My mistake... have a look at this thread... http://www.cadtutor.net/forum/showthread.php?t=10870 ... sounds like a prob with your mouse or it's driver. Quote
Hedgehog Posted February 4, 2008 Posted February 4, 2008 ... & here... http://www.cadtutor.net/forum/showthread.php?t=9366 ... &... http://www.cadtutor.net/forum/showthread.php?t=10296 http://www.cadtutor.net/forum/showthread.php?t=15299 http://www.cadtutor.net/forum/showthread.php?t=17527 ... I'm sure I could go on Quote
Strix Posted February 4, 2008 Posted February 4, 2008 do we have this covered in the FAQ then? *question to the FAQ team who know what we've also got in the pipeline* Bookmarked Quote
giraffe Posted January 5, 2010 Posted January 5, 2010 I do check as a rule.The post does not answer my question. I am not asking about PAN. I want my mouse wheel to zoom instead of moving the drawing up & down.?????? I had the same problem until i figured that my new Targus Comfort mouse had a brain of its own and was clashing with AutoCAD commands related to the Wheel. I just solved the problem and would like to share with others still struggling. Go to the task bar - lower right corner of your desktop and double click on the mouse icon (for me its called Targus Comfort Mouse Driver) in the new window that opens up - click on the tab that says BUTTONS, now change the setting for Wheel Button to "None" (it should still scroll up and down in most other applications) This solved by problem # 1 the PAN command and Zoom extends at double click. Then click on the WHEEL tab (on top of the mouse driver window) select: "Use Microsoft Office 97 Scrolling Emulation Only Apply then ok. This will solve problem # 2 realtime zoom using the mouse Wheel Go back to AutoCAD and check it. have fun drafting! Quote
