au-s Posted May 8, 2009 Posted May 8, 2009 Hello, I have this Lisp that inserts a block with an attributes. I use it to give a certain ID-number to doors, windows in drawings. Attributes in block called _Doorlitt are as follows: Tag: LITTERA Prompt: Littera Default: D_Litt In block _Windows it looks the same as above. When I insert it the blocks opens for editing, simple. Now ... is it a way for the main lisp to have a built in function which sees the last number in an ID like D_001 and when the user inserts the Door ID again (same block) it checks for the last Default and auto adds D_00(2) ... JUST LAST number... Thats important because sometimes a user might change the Default value to maybe Door_01 or Door1 or Door01 or maybe Door 1 (with space here). So... is that possible for lisp to read the last number from a specific block called _Doorlitt and to add the last number+1 in the Default value? If the user tries to change the last number it will still be renumbered to the last value. Thanx Quote
au-s Posted May 8, 2009 Author Posted May 8, 2009 I found this lisp: ;; Increment Text lisp routine;;;; by: Irné Barnard;; Version 1.2;; ;; Version history;; ==================================;; 1.2;; Added alphabetic increments;;;; 1.1;; Add prefix / suffix;; Add minimum digits;;;; 1.0;; Initial version;;(setq INCRset '(1 "" "" 1 1 t) alphalst '("A" "B" "C" "D" "E" "F" "G" "H" "J" "K" "L" "M" "N" "P" "Q" "R" "S" "T" "U" "V" "W" "X" "Y" "Z" )) ;_ end of setq;; Utility function to convert alpha number to integer;|(defun alphatoi (a / i neg n) (if (setq neg (= "-" (substr a 1 1))) (setq a (substr a 2)) ) (setq i a n (strlen i) a "") (while (> n 0) (setq a (strcat a (substr i n 1)) n (1- n)) ) (setq i 0 n 1) (while ( (if (= n (strlen a)) () (setq i (+ i (* (vl-position (1- n) ) ) (setq n (1+ n)) ) (if neg (setq i (* i -1))) i)|;;; Utility function to convert integer to Alpha number(defun itoalpha (i / a neg) (setq neg ( i (abs (fix i)) a "" ) ;_ end of setq (while (>= i 0) (setq a (strcat (nth (rem i (length alphalst)) alphalst) a)) (setq i (- i (rem i (length alphalst)))) (setq i (fix (/ i (length alphalst)))) (if (= i 0) (setq i -1) (if (/= (rem i) 0) (setq i (1- i)) ) ;_ end of if ) ;_ end of if ) ;_ end of while (if neg (setq a (strcat "-" a)) ) ;_ end of if a) ;_ end of defun;; Command to increment text values by picking(defun c:Increment (/ dcl_id obj objid id quit rate start value prfx sufx digits numerals) (setq start (nth 0 INCRset) prfx (nth 1 INCRset) sufx (nth 2 INCRset) rate (nth 3 INCRset) digits (nth 4 INCRset) numerals (nth 5 INCRset) ) ;_ end of setq (defun Setup () (setq DCL_ID (load_dialog "Increment.DCL")) (if (not (new_dialog "increment" DCL_ID)) (exit) ) ;_ end of if (defun CHECKOUT () (setq start (atoi (get_tile "start"))) (setq prfx (get_tile "prefix") sufx (get_tile "sufix") ) ;_ end of setq (setq rate (if (= (atoi (get_tile "one")) 1) "1" (if (= (atoi (get_tile "two")) 1) "2" "0" ) ;_ end of if ) ;_ end of if ) ;_ end of setq (setq rate (atoi (if (/= (atoi (get_tile "increase")) 1) (strcat "-" rate) rate ) ;_ end of if ) ;_ end of atoi ) ;_ end of setq (setq digits (atoi (get_tile "digits"))) (setq numerals (= (get_tile "num") "1")) (setq INCRset (list start prfx sufx rate digits numerals)) ) ;_ end of defun (defun DONE () (setq quit 1) ) ;_ end of defun (if (/= start nil) (set_tile "start" (itoa start)) ) ;_ end of if (if (/= prfx nil) (set_tile "prefix" prfx) ) ;_ end of if (if (/= sufx nil) (set_tile "sufix" sufx) ) ;_ end of if (if (/= digits nil) (set_tile "digits" (itoa digits)) ) ;_ end of if (if numerals (set_tile "num" "1") (set_tile "alpha" "1") ) ;_ end of if (if (/= rate nil) (progn (cond ((= rate 0) (set_tile "none" "1")) ((= rate 2) (set_tile "two" "1")) ((= rate -2) (set_tile "two" "1") (set_tile "decrease" "1")) ((= rate -1) (set_tile "decrease" "1")) ) ;_ end of cond ) ;_ end of progn ) ;_ end of if (action_tile "accept" "(CHECKOUT)(done_dialog)") (action_tile "cancel" "(DONE)(done_dialog)") (start_dialog) (unload_dialog DCL_ID) ) ;_ end of defun (SETUP) (while (/= quit 1)[color=red] (while (and (/= quit 1) (not (or (= id "TEXT") (= id "MTEXT") (= id "ATTRIB"))))[/color] (setq obj nil) (if numerals (progn (setq value (itoa start)) (while ( ) ;_ end of progn (progn (setq value (itoalpha start)) (while ( ) ;_ end of progn ) ;_ end of if (while (and (/= quit 1) (= obj nil)) (setvar "errno" 0) (initget 4 "Change") (setq obj (nentsel (strcat "\rSelect text...(" value ")[Change]"))) (cond ((= (getvar "errno") 52) (setq quit 1 obj 1 ) ;_ end of setq ) ((= obj "Change") (Setup) (setq obj nil)) ((/= obj nil) (setq objid (entget (car obj))) (setq id (cdr (assoc 0 objid)))) ) ;_ end of cond ) ;_ end of while ) ;_ end of while (if (/= quit 1) (progn (setq objid (subst (cons 1 (strcat prfx value sufx)) (assoc 1 objid) objid)) (entmod objid) (command "_updatefield" (car obj) "") (entupd (car obj)) (setq INCRset (list start prfx sufx rate digits numerals)) (setq start (+ start rate)) (setq id nil) (setq obj nil) ) ;_ end of progn ) ;_ end of if ) ;_ end of while (princ)) ;_ end of defun;;; ROUND Arrondit Quote
Lee Mac Posted May 8, 2009 Posted May 8, 2009 Does this help you? http://www.asmitools.com/Files/Lisps/Atnum.html Quote
Storm2002 Posted May 9, 2009 Posted May 9, 2009 This works great. Can it be tweaked to select a specific attribute if a block contains multiple attributes, for example a room name/number block? Thanks Derek Quote
Lee Mac Posted May 9, 2009 Posted May 9, 2009 Which routine are you referring to? ASMI's or the posted code? Quote
