The way we place our cursor over an object (without actually clicking) and it becomes highlighted, similarly I want to write code
that highlights certain portion of drawing, so that we can easily view it. For exampe I want to show the flow of water in pipes. If I hightlight the desired portion of pipes, In a drawing having thosands of other objects, the user will be able to easily view flow of water without caring about other objects present in thedrawing.
Some users may suggest that I turn off other layers and keep the water pipe layer on, but we need to view the water pipes
while other existing services suchs as ( telephone lines, undergroud electrictiy lines ) are also visible in the drawing.
Have you thought of using Layiso with the Settings > Lock and fade option?
Two options for you to play around with:
(defun c:hlight  (/ lLst lay ObjLst grdat iEnt)
 (vl-load-com)
 (vlax-for l
              (vla-get-layers
                (vla-get-ActiveDocument
                  (vlax-get-acad-object)))
   (setq lLst (cons (vla-get-Name l) lLst)))
 (if (and (setq lay (strcase (getstring t "\nSpecify layer to Highlight: ")))
          (member lay (mapcar 'strcase lLst)))
     (setq ObjLst (mapcar 'cadr (ssnamex (ssget "_X" (list (cons 8 lay))))))
     (princ "\nMove Cursor Over Objects....")
     (while (eq 5 (car (setq grdat (grread t 4 2))))
       (if (and (setq iEnt (car (nentselp (cadr grdat))))
                (eq lay (strcase (cdr (assoc 8 (entget iEnt))))))
         (mapcar '(lambda (x) (redraw x 3)) ObjLst)
         (mapcar '(lambda (x) (redraw x 4)) ObjLst))))
   (princ "\n<!> Layer not Found <!>"))
 (princ))
(defun c:hlight2  (/ lLst lay ObjLst NulLst grdat iEnt)
 (vl-load-com)
 (vlax-for l
              (vla-get-layers
           NulLst (mapcar 'cadr
                                          (list (cons -4 "<NOT")
                                                (cons 8 lay)
                                                (cons -4 "NOT>"))))))
           (mapcar '(lambda (x) (redraw x 2)) NulLst))
           (mapcar '(lambda (x) (redraw x 1)) NulLst)))))
 (princ))
Type "hlight" or "hlight2" to invoke
Edited by Lee Mac
This is actually probably more useful:
(defun c:hlight3  (/ lay ObjLst NulLst grdat iEnt)
   (if (setq iEnt (car (nentselp (cadr grdat))))
       (setq lay (strcase (cdr (assoc 8 (entget iEnt)))))
                                                  (cons 8 lay)
     (if (and ObjLst NulLst)
 (princ))
Type "hlight3" to invoke
Edited by Lee Mac
Another method:
Issue a regen to un highlite
;;     Sel.lsp by Charles Alan Butler
;;            Copyright 2004
;;   by Precision Drafting & Design All Rights Reserved.
;;   Contact at ab2draft@TampaBay.rr.com
;;    Version 1.0 Beta  July 23,2004
;;    Version 1.1 Beta  July 13,2005
;;   Creates a selection set of objects on a layer(s)
;;   User picks objects to determine the layer(s)
;;   Then User selects objects for ss or presses enter to
;;   get all objects on the selected layer(s)
;;   You may select the selection set before starting this
;;   routine. Then select the layers to keep in the set
(defun c:sel (/ ent lay ss lay:lst lay:prompt ss:first ent:lst)
;;  An integer value that controls the visibility and highlighting of the entity.
;;  The mode can be one of the following values:
;;  1  Show entity
;;  2  Hide entity (blank it out)
;;  3  Highlight entity
;;  4  Unhighlight entity
(defun ssredraw ( ss mode / i ename vlaobj)
 (and (eq 'pickset (type ss))
      (setq i -1)
      (while (setq ename (ssname ss (setq i (1+ i))))
          (setq vlaobj (vlax-ename->vla-object (ssname ss i)))
          (vla-Highlight vlaobj :vlax-true)
          (vla-update vlaobj)
 ;;  get anything already selected
 (setq ss:first (cadr(ssgetfirst))
       ss (ssadd))
 ;;  Get user selected layers
 (if ss:first
   (setq lay:prompt "\nSelect the object to choose layers to keep.")
   (setq lay:prompt "\nSelect object(s) for layer filter. ENTER to continue.")
 (while (setq ent (entsel lay:prompt))
   (setq ent:lst (cons (car ent) ent:lst))
   (setq lay:lst
          (cons (setq lay (cdr(assoc 8 (entget (car ent))))) lay:lst))
   (prompt (strcat "\n*-* Selected Layer -> " lay))
 ;;  Un HighLite the entities
 (and ent:lst (mapcar '(lambda (x) (redraw x 4)) ent:lst))
 (if (> (length lay:lst) 0); got layers to work with
     (setq lay "")
     (setq lay:lst (vl-sort lay:lst '<)) ; removes douplicates
     (foreach itm  lay:lst ; combine lay names into one , del string
       (setq lay (strcat lay itm ",")))
     (setq lay (substr lay 1 (1- (strlen lay)))); remove the last ,
     (if ss:first ; ALREADY GOT SELECTION SET
       (while (setq ent (ssname ss:first 0))
         (if (member (cdr(assoc 8 (entget ent))) lay:lst)
           (ssadd (ssname ss:first 0) ss)
         (ssdel (ssname ss:first 0) ss:first)
       (progn ; else get a selection set to work with
         (prompt (strcat "\nOK >>--> Select objects for Selection set or "
                         "ENTER for All objects on layer(s) " lay))
         ;;  get objects using filter with user select
         (if (null (setq ss (ssget (list (cons 8 lay)))))
           ;; or get ALL objects in current space using filter
           (setq ss (ssget "_X" (list (cons 8 lay)(cons 410 (getvar "ctab")))))
     (if (> (sslength ss) 0)
         (prompt (strcat "\n" (itoa (sslength ss))
                     " Object(s) selected on layer(s) " lay
                     "\nStart an ACAD command, REGEN to un highlite."))
         (ssredraw ss 3)
       (prompt "\n***  Nothing Selected  ***")
(prompt "\nSelect on Layer loaded, Enter Sel to run.")
  • 12 years later...
 (vl-load-com)
 (vlax-for l
              (vla-get-layers
 (princ))
 (vl-load-com)
 (vlax-for l
              (vla-get-layers
                                                (cons 8 lay)
 (princ))
the code highlight all the objects in the same layer and hide the others, theres a way just to highlight the object the cursor is over to show whitch line you will get selected if you click?
