muck Posted May 10, 2009 Posted May 10, 2009 Using AutoCAD VBA, Is it possable to access a text string in a block? I want to get a block textstring to change color or layer? Note, I am not taking about a block attribute. I am trying to access a string of text that is in the block. I am interested in acessing both the block definations and block references. I am also interested in accessing Mtext and dimensions in a block. Thank you, Quote
BIGAL Posted May 11, 2009 Posted May 11, 2009 Here is a change linetype example shopuld be able to change the code to search for text and then change. You can call lisp from VBA ;(defun c:normblocks (/ adoc) (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark adoc) (vlax-for block (vla-get-blocks adoc) (if (not (wcmatch (strcase (vla-get-name block) t) "*_space*")) (vlax-for ent block (if (= (vla-get-linetype ent ) "solid" ) (progn (vla-put-linetype ent "Continuous") (princ (vla-get-name block)) ) );_ end of if ) ;_ end of vlax-for ) ;_ end of if ) ;_ end of vlax-for (vla-regen adoc acactiveviewport) (vla-endundomark adoc) (princ) try replacing (if (= (vla-get-linetype ent ) "solid" ) with (if (=(vla-get-text ent ) mytext ) not sure if ok this code was done by but met my needs. Quote
