I worked with a CAD Demi-god that had a lisp that would turn plan pipng blocks into iso blocks for ball valves and such. I believe you had to explode the block first but, I'm not possitive on that. Dose anyone have a .lsp for that?
o:)P.s. I really miss the Demi-god and, hope he is making fat bucks where ever he's at. Bless him and all his lisp routines. amen
Please try:
(defun c:isoblock (/ blok_ent counter ent_data ent_pt i sub_func)
   (vl-load-com)
   (defun to_southwest	(ent_name base_pt / obj)
(vla-TransformBy
    (setq obj (vlax-ename->vla-object ent_name))
    (vlax-tmatrix
	(list
	    (list (/ (sqrt 2.) 2.) (- (/ (sqrt 2.) 2.)) 0. 0.)
	    (list (/ (sqrt (/ 2. 3.)) 2.) (/ (sqrt (/ 2. 3.)) 2.) (sqrt (/ 2. 3.)) 0.)
	    (list (- (/ (sqrt 3.) 3.)) (- (/ (sqrt 3.) 3.)) (/ (sqrt 3.) 3.) 0.)
	    (list 0. 0. 0. 1.)
(vla-move obj
	  (vlax-3d-point
	      (trans (cdr (assoc 10 (entget ent_name))) ent_name 0)
	  (vlax-3d-point base_pt)
   (defun to_southeast	(ent_name base_pt / obj)
(vla-TransformBy
    (vlax-tmatrix
	(list
	    (list (/ (sqrt 2.) 2.) (/ (sqrt 2.) 2.) 0. 0.)
	    (list (- (/ (sqrt (/ 2. 3.)) 2.)) (/ (sqrt (/ 2. 3.)) 2.) (sqrt (/ 2. 3.)) 0.)
	    (list (/ (sqrt 3.) 3.) (- (/ (sqrt 3.) 3.)) (/ (sqrt 3.) 3.) 0.)
	    (list 0. 0. 0. 1.)
(vla-move obj
	  (vlax-3d-point
   (defun to_front (ent_name base_pt / obj)
(vla-TransformBy
    (vlax-tmatrix
	(list
	    (list 1. 0. 0. 0.)
	    (list 0. 0. 1. 0.)
	    (list 0. 1. 0. 0.)	;mirrored
	    (list 0. 0. 0. 1.)
(vla-move obj
	  (vlax-3d-point
   (defun to_front_southwest (ent_name base_pt / obj)
(to_front ent_name base_pt)
(to_southwest ent_name base_pt)
   (defun to_front_southeast (ent_name base_pt / obj)
(to_southeast ent_name base_pt)
   (if	(setq blok_ent (car (entsel "\n>>>...Pick a block...>>>: ")))
    (setq ent_data (entget blok_ent))
    (setq ent_pt (cdr (assoc 10 ent_data)))
    (to_southwest blok_ent ent_pt)
    (setq counter 1)
    (while (= (setq i (strcase (getstring "\rPress [Enter] to Toggle or Press any key to exit: "))) "")
	(if blok_ent
	    (vla-delete (vlax-ename->vla-object blok_ent))
	(setq sub_func
		 (nth counter
		      '(to_southwest
			to_southeast
			to_front_southwest
			to_front_southeast
	(entmake ent_data)
	(setq blok_ent (entlast))
	((eval sub_func) blok_ent ent_pt)
	(if (< counter 3)
	    (setq counter (1+ counter))
	    (setq counter 0)
);...........................................wiz11May09
thanks lee, i just rotated the block, im not sure if the OP still needs to explode then flatten then turn to block again. keep up your good work lee.
