Zorg Posted May 11, 2009 Posted May 11, 2009 Can anyone write me a LISP that will reconcile all layers without having to bring up the Layer manager. Im doing batch plots and theres a problem with my layer manager where it is incredible laggy (Probably because of the amount of drawings i have open ). So i'd like to just run a LISP ('RCO') and have no prompt for Yes or No. Many, many thanks in advance. Z Quote
Tiger Posted May 11, 2009 Posted May 11, 2009 how about changing the value of LAYEREVAL instead? Set it to 0 and see what happens. Quote
Zorg Posted May 11, 2009 Author Posted May 11, 2009 Uhh, not too sure what that was meant to do. Didn't stop the layers needing to be reconciled before being allowed to plot. Quote
Zorg Posted May 11, 2009 Author Posted May 11, 2009 Cheers! Mine was set to 15 for some reason! :s Quote
Tiger Posted May 11, 2009 Posted May 11, 2009 LAYERNOTIFYs availible settings: 0 - off 1- Plot 2- Open 4- Load /reload /attacch for xrefs 8 - restore layer state 16 Save 32 - Insert 15 is default and would be 8+4+2+1 = will notify for layers at plot, open, load7reload/attach xrefs and when restoring layer states. Quote
Zorg Posted May 11, 2009 Author Posted May 11, 2009 ! Even better! im gonna keep 'Load/Reload' on. I'm only human after all Quote
The Buzzard Posted May 11, 2009 Posted May 11, 2009 LAYERNOTIFYs availible settings: 0 - off 1- Plot 2- Open 4- Load /reload /attacch for xrefs 8 - restore layer state 16 Save 32 - Insert 15 is default and would be 8+4+2+1 = will notify for layers at plot, open, load7reload/attach xrefs and when restoring layer states. Thank you Tiger, I had version 2009 for a short while and I find that there is alot of changes here. This is good to know. Quote
Freerefill Posted May 11, 2009 Posted May 11, 2009 I figure there's a reason for the notification.. sure it would be very nice to suppress, but will everything still plot fine regardless of whether or not the layer has been reconciled? Quote
Tiger Posted May 11, 2009 Posted May 11, 2009 I figure there's a reason for the notification.. sure it would be very nice to suppress, but will everything still plot fine regardless of whether or not the layer has been reconciled? I removed everything regarding reconciled layers from the start of 2008 - and never had any troubles with it. Quote
