I didn't get much sleep last night and I -know- there's an easy way to do this...
What's an easy way to copy a piece of text? And I know "Ctrl+C", I'm actually asking for something different. Using (nentsel) (thanks Lee ^.^) one can get data of a blocked bit of text.. if one were to create a new piece of text in the exact same location of the exact same size and content.. right now, I created a new piece of text and then matched the VLA attributes, like,
(vla-put-InsertionPoint lasEnt (vla-get-InsertionPoint ent))
I did this for every necessary attribute.. is there a better way? Will (command "copy") work for this, even if it's text stuffed within a block?
Thanks ^.^
I actually created a lisp this weekend... So are you looking to copy just text or text nested in a block? cause if it's just text i would consider copybase. if not then i can give you my lisp in the morning
When you say "copy an attribute", if you want the return to be a new attribute, then I was just messing around with this:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:ctxt  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] doc spc tEnt tObj[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-Acad-Object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       spc [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]zerop[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-activespace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]=[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-mspace[/color][/b] doc[b][color=RED])[/color][/b] :vlax-true[b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]vla-get-modelspace[/color][/b] doc[b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]vla-get-paperspace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]vla-get-modelspace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tEnt [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]nentsel[/color][/b] [b][color=#ff00ff]"\nSelect Text Object: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] tEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                  [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"TEXT"[/color][/b] [b][color=#ff00ff]"MTEXT"[/color][/b] [b][color=#ff00ff]"ATTRIB"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tObj [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] tEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] tEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"TEXT"[/color][/b] [b][color=#ff00ff]"MTEXT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]vla-move[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]vla-copy[/color][/b] tObj[b][color=RED])[/color][/b]
                [b][color=RED]([/color][/b][b][color=BLUE]vla-get-InsertionPoint[/color][/b] tObj[b][color=RED])[/color][/b]
                  [b][color=RED]([/color][/b][b][color=BLUE]vlax-3D-point[/color][/b]
                    [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b] [b][color=#ff00ff]"\nSelect New Location: "[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]10[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] tEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b]T
              [b][color=RED]([/color][/b][b][color=BLUE]vla-addAttribute[/color][/b] spc
                [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Height[/color][/b] tObj[b][color=RED])[/color][/b] [b][color=#009900]0[/color][/b]
                  [b][color=RED]([/color][/b][b][color=BLUE]vla-get-TagString[/color][/b] tObj[b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]vla-get-TagString[/color][/b] tObj[b][color=RED])[/color][/b] [b][color=#ff00ff]""[/color][/b][b][color=RED])[/color][/b]
                              [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray->list[/color][/b]
                                [b][color=RED]([/color][/b][b][color=BLUE]vlax-variant-value[/color][/b]
                                  [b][color=RED]([/color][/b][b][color=BLUE]vla-get-InsertionPoint[/color][/b] tObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<!> Incorrect Selection <!>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
I'm guessing you were more after something like this:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:ctxt  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] doc spc tEnt tObj mtxt[b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] mtxt
              [b][color=RED]([/color][/b][b][color=BLUE]vla-addMText[/color][/b] spc
                [b][color=RED]([/color][/b][b][color=BLUE]vla-get-InsertionPoint[/color][/b] tObj[b][color=RED])[/color][/b] [b][color=#009900]0[/color][/b]
                  [b][color=RED]([/color][/b][b][color=BLUE]vla-get-TextString[/color][/b] tObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]vla-put-layer[/color][/b] mtxt [b][color=RED]([/color][/b][b][color=BLUE]vla-get-layer[/color][/b] tObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]vla-put-StyleName[/color][/b] mtxt [b][color=RED]([/color][/b][b][color=BLUE]vla-get-StyleName[/color][/b] tObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                [b][color=RED]([/color][/b][b][color=BLUE]vla-put-color[/color][/b] mtxt [b][color=RED]([/color][/b][b][color=BLUE]vla-get-color[/color][/b] tObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                  [b][color=RED]([/color][/b][b][color=BLUE]vla-put-height[/color][/b] mtxt [b][color=RED]([/color][/b][b][color=BLUE]vla-get-height[/color][/b] tObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]vla-move[/color][/b] mtxt
              [b][color=RED]([/color][/b][b][color=BLUE]vla-get-InsertionPoint[/color][/b] mtxt[b][color=RED])[/color][/b]
                        [b][color=RED]([/color][/b][b][color=BLUE]vla-get-InsertionPoint[/color][/b] mtxt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
