How can I start up AutoCAD and not have a blank drawing show up?
I work the majority of the time with existing drawings and I am tired of closing Drawing1.dwg every time.
I looked for a command line switch for the shortcut icon, but, no joy.
Any suggestions?
  • Replies 34
  • rkmcswain
    7
  • AirSchatz
    6
  • alanjt
    4
  • Luvrbcs
    3
Startup=1 ...
That gave me a dialog box for Open a drawing. Not quite what I want. I want it to go to a blank screen that is like the screen you get when you close all your drawings. Nothing.
Thanks anyways.
Read this Open AutoCAD without a New Drawing
You could put (command "CLOSE") (the part in red) in your acad.lsp, just make sure you do not have acad.lsp to open with every drawing _ACADLSPASDOC = 0.
Thanks, SLW210. That is exactly what I was looking for.
I used the close.scr option.
  • 1 year later...
THANK YOU! haha i have tried everything, then i found this thread- tried all of those except for..
(command "CLOSE")
^THIS!!
i'm running adt08 and this was the only thing that was successful for me. Thank you again SLW210!
  • 1 month later...
does this work with AutoCAD MEP 2010? I tried it, but it kept shutting the whole cad program down. How does it need to be coded?
I'm just curious as to what difference it makes, because as soon as you open a new or existing drawing, "drawing1.dwg" closes....:?:
this might be a little safer:
(and (wcmatch (getvar "dwgname") "Drawing*")
    (zerop (getvar "sdi"))
    (command "_.close" "_y")
) ;_ and
....and then you navigate to your existing drawings. I have never understood why this isn't an option for people. You have to navigate to the file one way or another, may as well be in autocad.
I tried that code, but it just makes AutoCAD MEP close completely when finished opening.
As far as the drawing1.dwg closing when you opening an existing drawing, not on my machine, if that's an option that would work to, but drawing1.dwg stays open and I have to close it manually..
Any other suggestions?
Thanks guys
Thanks guys
did you try the one i posted, it will check if the sdi mode is set to 0, if not, it will not continue and try to close the drawing.
Then something is modifying the drawing at startup. As soon as AutoCAD opens with drawing1.dwg - type in DBMOD at the command line. If it's not zero (0), then something is modifying the drawing.
If DBMOD = 0 AND you start another drawing or open an existing one, then "drawing1.dwg" closes.
If DBMOD /= 0 AND SDI = 0, AND you start another drawing or open an existing one, then "drawing1.dwg" stays open.
If DBMOD /= 0 AND SDI = 1, AND you start another drawing or open an existing one, then you will be prompted to save "drawing1.dwg".
I did try that, but when I open ACAD, it loads up then when the drawing1.dwg would the whole program just shut down. But then again, maybe I put the code in the wrong place....I inserted at the bottom of of the acad2010doc.lsp. I couldn't find the acad.lsp. Also, this is a AutoCAD MEP 2010 programs.
Thanks for your help
the DBMOD = 20 (read only)......what does that mean?
maybe something like this?
(and (eq (getvar "dwgname") "Drawing1.dwg")
    (if (zerop (getvar "dbmod"))
      (command "_.close")
    ) ;_ if
) ;_ and
You can find all the system variables in HELP.
A DBMOD value of 20 means that the view has been modified and a database variable has been modified.
First off, "acad2010doc.lsp" is executed every time a drawing is opened. Secondly, that file "belongs" to AutoCAD, meaning that it can be overwritten by reinstalls, service packs, upgrades, etc. Anything you put in here will probably be lost someday.
"Acad.lsp" is only executed at application startup (assuming ACADLSPASDOC is not changed from its default value of zero), and is "owned" by the user. AutoCAD will never touch this file, it's under your control. Because it's a user file, you have to create it. It doesn't exist OOTB.
That makes sense....The Acad.lsp you are talking about, is that the same as Acad2010.lsp? That was the only other lsp file in the support folder.
Thanks for the help guys, this forum rawks.....
No! acad2010.lsp is "owned" by AutoCAD also.
"acad.lsp" and "acaddoc.lsp" are the USER equivalents to "acad2010.lsp" and "acad2010doc.lsp" There is just no reason to edit the latter two files.
See: http://usa.autodesk.com/getdoc/id=TS21336
