ACAD 2010-REFEDIT - Can add more of the same block :(
Hi,
Using refedit, I get this error (warning)
Select objects: 1 found
Select objects: Block was not added to the work set.
Its name conflicts with a block already in the work set.
It is a window block that I have in several places in modelspace.
Used to work in 2007/8/9....
  • 3 weeks later...
Hmm, looks like I'll need to go back to using 2007 :(
I am having the same issue.Any solution yet or wait for SP1
  • 5 months later...
**PROBLEM SOLVED**
Good news, it is solved in the latest Service Pack.
