florin Posted May 14, 2009 Posted May 14, 2009 I have one dwg file with 10 tabs, each having material bill (as excel embedded file). The bill (excel file) is the same in each tab. When I try to open the material bill, only from the first tab, AutoCad gives me these messages. For others tabs it works. What is the solution? Can I control the memory used for this operation (variable name)? Thanks Quote
ReMark Posted May 14, 2009 Posted May 14, 2009 Insufficient memory errors can sometimes be attributed to a small or overfilled "swap file". This is where Windows, having run out of available physical memory, "pages out" data to the hard drive. It may also be referred to as virtual memory. What OS are you running and how much physical RAM is installed in your computer? Quote
