i was thinking of upgrading my home pc and i was considering eather
1 of the Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16\
Model
Brand GIGABYTE
Model GV-R485OC-1GH
Interface PCI Express 2.0 x16
Chipset Manufacturer ATI
GPU Radeon HD 4850
Core Clock 700MHz
Stream Processors 800 Stream Processing Units
Memory Clock 1920MHz
Memory Size 1GB
Memory Interface 256-bit
Memory Type GDDR3
DirectX DirectX 10.1
OpenGL OpenGL 2.1
or
2 of the Radeon HD 4650 1GB 128-bit GDDR2 PCI Express 2.0 x16
Model
Brand GIGABYTE
Model GV-R465OC-1GI
GPU Radeon HD 4650
Core Clock 650MHz
Stream Processors 320 Stream Processing Units
Memory Clock 800MHz
Memory Size 1GB
Memory Interface 128-bit
Memory Type GDDR2
OpenGL OpenGL 2.0
what would you choose (same cost in the end)
i will run auto cad 2009 and inventor 2009 maybe 2010
sorry they were mixed up and i fixed it
one more thing im running windows 7 rc will i get any other problems or will it run as it was on vista
Is it just me or are those two sets of specifications mixed up?
If I'm right on that I would go with number 1. Its is the more advanced card and it seems to match up nicely to the specifications of the navida quadro range of cards in that price range.
but out of those 2 what would be the best to run auto cad and inventor the 1 of the 4850 or 2 of the 4650
well obviously the 4850 by spec alone. But you won't see me wasting money on a gaming card for a CAD app. :)
well my main use of the power is gaming but i just want to make sure it will run auto cad
  • 2 weeks later...
I would get the HD4770 over the 4850 because of its lower cost and nearly identical performance.
  • 1 month later...
Either would work but, do you need a gaming video card?
I find AutoCAD my game. I leave gaming, bang, bang, up to the youngsters.
A workstation desktop or laptop would be my choice.
If you are a hard core gamer then stick with the gaming card (Radeon vs. FireGL). It can handle the CAD side suitably well but not perfect.
  • 4 weeks later...
First card has a memory bandwidth of 61Gb/s.
2nd Card, 25Gb/s.
1st post
  • 10 months later...
Recommend u to use ONDA HD5750 1024MB Graphics Cards
Graphics core
Graphics chip: parameter error correction Radeon HD 5750
Chip manufacturers: ATI correction parameters
Manufacturing Process: 40 nm correction parameters
Core code: parameter error correction RV840
Card frequency
Core frequency: 850MHz correction parameters
Memory Frequency: 4800MHz correction parameters
Memory Specifications
Memory Type: GDDR5 correction parameters
Memory capacity (MB): parameter error correction 1024
Memory Interface: 128bit correction parameters
The maximum resolution: 2560 * 1600 correction parameters
Graphics card cooling
Cooling: parameter error correction cooling fan
Graphics Interface
Bus Interface: PCI Express 2.0 16X parameter correction
Input / output interface: HDMI error correction parameters
Display interface: parameter error correction 24-pin DVI-I interface / 15-pin D-(VGA) Interface
Physical Characteristics
3D API: DirectX 11 parameter correction
SP cells: parameter error correction 720
