Polstar Posted May 15, 2009 Posted May 15, 2009 Hi all, the first of many posts from me! I am now making a concerted effort to learn ADT 2005! I have started a new project - the conversion of 2 terraced houses into apartments. My first question is about levels. In the Project tab of the project browser i have added each of the levels but i am unsure as to the floor to floor heights at the moment. I have measured floor to ceiling and up the stairs but have yet to determine the floor to floor height. Is it likely that i would have to do a quick sketch using lines to construct the section to determine what these heights are going to be or can i change them as and when i need to? Quote
Noahma Posted May 16, 2009 Posted May 16, 2009 You can change them when you need to, make sure you let it refresh your project afterwords. Also check you wall heights after such a change to ensure they have the proper height. Quote
