I can't for some reason get it to move the block now in any other direction but +x now. It gives me the prompt for all four but no matter which one I pick it move +X.
  • Replies 70
  • NH3man!
    38
  • Lee Mac
    29
  • lpseifert
    1
  • Freerefill
    1
I take that back. It will move in the +Y also. But not the -Y and -X. Could this be a one of toughs syntacs things you were talking about.
It all seems to work for me :)
I have added an UNDO to this one:
(defun c:hc  (/ *error* vlst ovar cBlk tmp1 tmp2 tmp3 tmp4 blkpt)
 ; Error Handler
 (defun *error*  (msg)
   (if ovar
     (mapcar 'setvar vlst ovar)) ; Return System Variables
   (if (not (member msg '("Function cancelled" "quit / exit abort")))
     (princ (strcat "\n<< Error: " msg " >>"))) ; Print Error Message
   (princ))
 ; Collect and Set System Variables
 (setq vlst '("CMDECHO" "OSMODE")
       ovar (mapcar 'getvar vlst))
 (mapcar 'setvar vlst '(0 0))
 ; Set Defaults
 (or hc$slp:def (setq hc$slp:def 1))
 (or hc$cop:def (setq hc$cop:def 1))
 (or hc$spc:def (setq hc$spc:def 1))
 (or hc$dir:def (setq hc$dir:def "X"))
 ; Get Block to Copy
 (if (and (setq cBlk (car (entsel "\nSelect Block: ")))
          (eq "INSERT" (cdr (assoc 0 (entget cBlk)))))
 ; Get User Input
     (initget 6)
     (setq tmp1 (getreal (strcat "\nSpecify Slope <" (rtos hc$slp:def) "> : ")))
     (or (not tmp1) (setq hc$slp:def tmp1))
     (initget 6)
     (setq tmp2 (getint (strcat "\nSpecify Number of Copies <" (itoa hc$cop:def) "> : ")))
     (or (not tmp2) (setq hc$cop:def tmp2))
     (initget 6)
     (setq tmp3 (getreal (strcat "\nSpecify Spacing <" (rtos hc$spc:def) "> : ")))
     (or (not tmp3) (setq hc$spc:def tmp3))
     (initget "X Y -x -y")
     (setq tmp4 (getkword (strcat "\nSpecify Axis [X/Y/-X/-Y] <" hc$dir:def "> : ")))
     (or (not tmp4) (setq hc$dir:def tmp4))
 ; Get Block Insertion Point Information and Initiate Counter
     (setq blkpt (cdr (assoc 10 (entget cBlk)))
           i     1)
 ; Copy the Block a Number of Times
     (command "_undo" "_Begin")
     (repeat hc$cop:def
       (command "_copy" cBlk "" blkpt)
       (cond ((eq "X" hc$dir:def)
              (command
                (list (+ (* i hc$spc:def) (car blkpt))
                      (cadr blkpt)
                      (+ (* i (/ hc$spc:def 12.) hc$slp:def) (caddr blkpt)))))
             ((eq "Y" hc$dir:def)
              (command
                (list (car blkpt)
                      (+ (* i hc$spc:def) (cadr blkpt))
             ((eq "-x" hc$dir:def)
              (command
                (list (+ (* -1. i hc$spc:def) (car blkpt))
                      (cadr blkpt)
             ((eq "-y" hc$dir:def)
              (command
                (list (car blkpt)
                      (+ (* -1. i hc$spc:def) (cadr blkpt))
             ) ; end cond
       (command)
       (setq i (1+ i)))
     (command "_undo" "_End"))
 ; Else No Block was Selected
   (princ "\n<!> No Block Selected <!>"))
 ; Return Sys Vars Back
 ; Exit Cleanly
 (princ))
Try reloading the code, and make sure you have this version loaded :)
Here is what I found. As long as I type in the new direction on the command line it will move in that direction. But in I click in the prompt box it just takes the last function and uses it.
Not sure about that - in '04 you can't click in the prompt box... :unsure:
I can't at work either I disabled it. This laptop they gave me I hardly ever use so didn't really set the configuration as I like it.
Thanks again Lee.
PS I was up till 2 in the morning reading about all though lsp terms.
Nice one - if you need any clarification on anything, just ask :)
Have you tried 3DARRAY.LSP that come with acad? -David
Will look into it. Didn't know it could go in one direction and elevate up or down. Thanks David.
(setq tmp4 (getkword (strcat "\nSpecify Axis [sZ] : ")))
I ran into a problem sort of. I have found that I am not always moveing just the x or y direction. So I tried to edit the axis part of the prompt with an Alias I have for snap angle. I have tried to put in the regular command and my alias but can't seem to get it to work. What else am I missing to get this to go to the angle I have my snap and curser set at.
(cadr blkpt)
Lee in this part of your code, I can't seem to figure out what the * and i are doing. I almost understand the rest. I am thinking it has something the starting point of the last block copied but at this point I am guessing.
Oh one more thing. Why won't the (rtos) accept a negetive numbuer> i.e. -.125
(cadr blkpt)
The i is incremented by 1 on every repeat, hence the block spacing is multiplied by this increment.
-.125 is not a real number - you need to specify -0.125
Thanks Lee, I get it now!!!!
I have used this today and it works like a champ. Lee if there is anything I can do for you I am willing. Not only for your hard work but for your teaching ability. You have mad me look into ACAD like I just started. I thank you for that.
Thank you,
NH3man!
Thank you,
NH3man!
Thanks NH3man!,
Your thanks is sufficient repayment -
I'd be more than happy to answer any other questions regarding this, or any other code I have posted on this site - as it helps me learn more about it by teaching someone else :)
Thanks
Lee
I tried entering it in like that and it say it has to be a non-negative number. It is not a big deal I always now which way the blocks need to slope.
that is to do with the "initget" argument that I included to disallow negatives.
Change the correct (initget 6) to an (initget 2) to get around this.
