Menolik Posted May 18, 2009 Posted May 18, 2009 I have a flattened helix that I would like to sweep a circle around. Whenever I try to do this; my computer freezes. When I try it by setting the helix's height to a minimum value, it says that the shape cannot be swept. What could be causing this? Quote
ReMark Posted May 18, 2009 Posted May 18, 2009 I've only had one cup of coffee this morning and my brain is kind of foggy so forgive me for asking. How did you expect to sweep a circle around a flattened helix? That's why AutoCAD is prompting for a minimum height value. The sweep should have been done with the helix still in 3D. Your system either froze because it couldn't complete the process or perhaps it is a memory issue. How much onboard RAM do you have? Quote
Menolik Posted May 18, 2009 Author Posted May 18, 2009 I just need to make a spring with no rise. Like a watch spring. Quote
JD Mather Posted May 18, 2009 Posted May 18, 2009 I just need to make a spring with no rise. Like a watch spring. So you want a coil, not a helix? Did you make the cross-section profile such that it does not self-intersect? Is this going to be game of 20 questions or are you going to attach what you have so far? Have you gone through the tutorials in my signature? Is something like Fig 38 in Tutorial 1 what you are after? Quote
Cad64 Posted May 18, 2009 Posted May 18, 2009 You could EXTRUDE the circle using the Path option: http://www.we-r-here.com/cad/tutorials/level_3/3-7a.htm Quote
Menolik Posted May 18, 2009 Author Posted May 18, 2009 Nevermind I'm an idiot. I just swept it around a helix of a certain height and then used the grip to flatten it. Quote
JD Mather Posted May 18, 2009 Posted May 18, 2009 Nevermind I'm an idiot. I just swept it around a helix of a certain height and then used the grip to flatten it. Sounds like extra work. You should be able to use the Helix command to create a coil path for sweep. Quote
