wakibd Posted May 19, 2009 Posted May 19, 2009 how can i convert any circle, rectangles or any shape to wipeout frame. Quote
tzframpton Posted May 19, 2009 Posted May 19, 2009 Circles can't be converted. a closed polyline can though. type WIPEOUT and P for polyline. Then select the object. Quote
rkmcswain Posted May 19, 2009 Posted May 19, 2009 Just draw a POLYGON with like, 100 sides. This should be close enough to mimic a circle. Quote
wakibd Posted May 19, 2009 Author Posted May 19, 2009 I have drawn a closed polyline nad use wipeout command . still this closed polyline is not converted to wipeout frame Command: wipeout Specify first point or [Frames/Polyline] : p Select a closed polyline: The polyline must be closed and made up of only line segments. Quote
rkmcswain Posted February 8, 2011 Posted February 8, 2011 I have drawn a closed polyline nad use wipeout command . still this closed polyline is not converted to wipeout frame Command: wipeout Specify first point or [Frames/Polyline] : p Select a closed polyline: The polyline must be closed and made up of only line segments. I suspect you only think you have drawn a closed polyline. Select it and view the properties. When you draw a polyline and snap the last vertex to the beginning one.... you DO NOT get a closed polyline. You should always draw all segments of the polyline except the last one, then use the "C" option to close it. Quote
MC5fan1968 Posted March 26, 2018 Posted March 26, 2018 Lee Mac Programming has a LISP that will wipeout circles. Circular: http://www.lee-mac.com/cwipe.html Quote
